Fuell cell issues
10-15-2009, 08:51 PM
Fuell cell issues
I bought this fuell cell but after i unpacked it i found out i bought the wrong one because it doesnt have a return.. It has a filler, feed (blue) and vent(red) but i doesnt have a return ![]() Now i was think to make a return in the filler neck but i dont know if this is possible. i was thinking of drilling a hole in the filler neck, put a nipple in it and put the fuell return on it. Will that work? |
10-15-2009, 09:38 PM
Fuell cell issues
Should work just fine. If there's enough flat area on the filler neck adapter, you could ask someone with aluminium welding gear to weld one of these on the drilled hole for a clean AN-6 hose attachment.
[img name=]http://www.aeu86.org/files/su/sum_220060_w_352.jpg[/img] |
10-15-2009, 10:20 PM
Fuell cell issues
yup
![]() ![]() If your going to refuel with the fuel pump on , make sure you point the nipple down, so it doesn't splash when you open the fuel cap. |
Running issues | sam3007 | 6 | 2,985 |
Over heating issues | MIGGZFSU | 12 | 12,024 |
Shortshifter TRD - Issues | pack | 13 | 12,973 |
09-19-2016 10:57 PM Last Post: jondee86 |
20v Starting Issues | mad.matt | 10 | 11,948 |
09-24-2014 12:44 PM Last Post: pack |
SR20DET (S13) gearbox shifting issues in AE86 | heshan | 8 | 11,472 |
07-22-2014 01:07 PM Last Post: heshan |
