Gas Door Quesiton
06-17-2009, 09:41 AM
Gas Door Quesiton
My Hachi's gas door has a key hole, But I saw many gas dorr without key hole.
Here is the question; how is the cap of the gas tube? I would like to see gas cap of them. Because I am going to remove the key hole |
06-17-2009, 11:49 AM
Gas Door Quesiton
There is no lock on the cap. In stead you open the gas door by wire from...
06-17-2009, 05:25 PM
Gas Door Quesiton
Jan Pedersen Wrote:There is no lock on the cap. In stead you open the gas door by wire from... haha LOL that was really easy answer I have ever get Mine has a Lock Can I convert it to the wire system ? |
06-17-2009, 06:38 PM
Gas Door Quesiton
Yep. Just find the original AE86 wire, handle and door lock and it should work.
06-18-2009, 10:27 AM
Gas Door Quesiton
WTB: Original gas door wire, handle and door Lock LOL
06-18-2009, 12:20 PM
Gas Door Quesiton
I took handel, wire and lock from a FWD E80
06-18-2009, 12:24 PM
Gas Door Quesiton
BTW If you take the rear door lock from a five door E80 you can open this by wire as well - its plug and play! You just need two long wires
06-19-2009, 02:56 PM
Gas Door Quesiton
Jan Pedersen Wrote:BTW If you take the rear door lock from a five door E80 you can open this by wire as well - its plug and play! You just need two long wires hell yeah! thank you so much dude! |
06-19-2009, 04:14 PM
Gas Door Quesiton
No problem, mate
06-20-2009, 02:58 PM
Gas Door Quesiton
Using the one from a TA60 Carina will also work: it is the same as well.
I presume other toyotas from the early 80s will feature the same system as well. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
4age hitting gas too quick means engine stalls - what is the issue? | Ryo | 20 | 28,869 |
06-27-2018 11:15 PM Last Post: Ryo |
3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 6,142 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
4age Gas smell | ae86canarias | 4 | 8,998 |
07-02-2012 04:21 PM Last Post: ae86canarias |
4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 7,714 |
10-01-2011 09:47 AM Last Post: demogun |
Replacing the gas tank | amigaguy | 12 | 23,514 |
07-29-2009 10:36 PM Last Post: amigaguy |
