Gas Door Quesiton
06-17-2009, 09:41 AM
Gas Door Quesiton
My Hachi's gas door has a key hole, But I saw many gas dorr without key hole.
Here is the question; how is the cap of the gas tube? I would like to see gas cap of them.
Because I am going to remove the key hole Smile
06-17-2009, 11:49 AM
Gas Door Quesiton
There is no lock on the cap. In stead you open the gas door by wire from...
[Image: AEU86 AE86 - Gas Door Quesiton]
06-17-2009, 05:25 PM
Gas Door Quesiton
Jan Pedersen Wrote:There is no lock on the cap. In stead you open the gas door by wire from...
haha LOL that was really easy answer I have ever get Big Grin
Mine has a Lock Sad Can I convert it to the wire system ?
06-17-2009, 06:38 PM
Gas Door Quesiton
Yep. Just find the original AE86 wire, handle and door lock and it should work. Wink
06-18-2009, 10:27 AM
Gas Door Quesiton
WTB: Original gas door wire, handle and door Lock LOL Big Grin
06-18-2009, 12:20 PM
Gas Door Quesiton
I took handel, wire and lock from a FWD E80 Wink
06-18-2009, 12:24 PM
Gas Door Quesiton
BTW If you take the rear door lock from a five door E80 you can open this by wire as well - its plug and play! You just need two long wires Thumbs up!
06-19-2009, 02:56 PM
Gas Door Quesiton
Jan Pedersen Wrote:BTW If you take the rear door lock from a five door E80 you can open this by wire as well - its plug and play! You just need two long wires Thumbs up!
hell yeah!
thank you so much dude!
06-19-2009, 04:14 PM
Gas Door Quesiton
No problem, mate Smile
06-20-2009, 02:58 PM
Gas Door Quesiton
Using the one from a TA60 Carina will also work: it is the same as well. Smile
I presume other toyotas from the early 80s will feature the same system as well. Wink
  4age hitting gas too quick means engine stalls - what is the issue? Ryo 20 28,869 06-27-2018 11:15 PM
Last Post: Ryo
  3rd door support gas springs (stay) - worn out max_ae86 5 6,142 09-01-2013 03:20 PM
Last Post: Jezza_hr
  4age Gas smell ae86canarias 4 8,998 07-02-2012 04:21 PM
Last Post: ae86canarias
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 7,714 10-01-2011 09:47 AM
Last Post: demogun
  Replacing the gas tank amigaguy 12 23,514 07-29-2009 10:36 PM
Last Post: amigaguy
