Gearbox Speedometer Driven & Drive Gear
12-18-2010, 12:34 PM
Hi guys!
I've recently disassembled my gearbox to repair some synchros and as I have the 4.778 ring and pinion, I may want to change the gearbox's speedometer driven and drive gear to get the dashboard to read speed correctly. I've got 19 teeth driven gear and 5 drive gear. 5:19 = 3.8 Stock final drive is 4.3 and mine is 4.778. 4.778:4.3 makes for a difference of 11%. My maths tell me I need to go from 5:19 to 5:21. I found in the internet that there are many drive and driven gears. the available drive gears are : 33481-12030 N=5 33481-14040 N=6 Driven gears: 33403-19135 N=19 33403-19155 N=20 33403-19165 N=21 33403-19175 N=22 My doubt is if the 21 teeth driven gear will match the 5 teeth drive gear. I know from toyodiy.com that the AE71 uses the 21 driven gear and 6 drive gear. Has anyone tried this already? Thanks in advance! |
12-18-2010, 04:14 PM
Hi mate,
I have recently rebuilt my gearbox and changed the final drive to 4.778:1 as well, so I tried 21 teeth driven on the stock 5 teeth drive gear and it fits and rotates properly. SFD |
12-18-2010, 10:50 PM
Is the part number the same I described?
Thank you! |
12-18-2010, 11:32 PM
that's interesting info
![]() '87 levin coupé ![]() |
12-20-2010, 09:27 AM
Aha! Found that link I was talking about on club4ag, even though it wasn't a thread on club4ag:
http://www.hachiroku.net/forums/showthread.php?t=11168 Looks like 22/5 would be what you want. Andrew |
12-20-2010, 10:16 PM
Interesting!! I had mine changed last summer, and the speedometer was way of, more than 11%... more like 20% :-(
Digital speedometer on stock dashboard | FanIsHere | 0 | 2,126 |
5th gear issue | r.ave | 1 | 3,416 |
03-14-2021 08:52 PM Last Post: Ivan141 |
ring gear bolts | DJexor | 3 | 6,372 |
12-26-2016 10:56 PM Last Post: totta Crolla |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 7,559 |
11-27-2015 10:06 AM Last Post: Project D |
Final drive calculation. | Aram | 31 | 36,681 |
12-24-2014 03:08 PM Last Post: Uzelac |
