02-28-2007, 01:31 PM
Post: #211
So we'll get Zeus and Ra locked in mortal combat here then?
Cool! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
02-28-2007, 03:36 PM
Post: #212
nmwisima Wrote:Apolan Wrote:i always loved that hachiroku of your the best from all the greeks youre not even a contender anymore girly-car racer ![]() ![]() ![]() |
02-28-2007, 03:44 PM
Post: #213
hahahahahahahahahaa
![]() AE86 FANATIC!!! |
Post: #214
You guys are f**ing Doritos topic for no reason.
danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
03-28-2007, 01:54 PM
Post: #215
Update: Yesterday I brought back home with me
-> My old gearbox (the one destroyed by stupid mechanic - look on previous pages). I'm gonna open it with the help of a friend and try to salvae what I can. I might even repair it if there's no major damae to gears or primary shaft. -> The A/C the car had on it when I first bought it (3 years ago). It's complete with all the needed paraphernalia, but it needs some serious servicing before it's ready to put back on the car. Actually I'm undecided whether I'll mount it or not, due to the added weight. On the other hand, it's quite a usefull adet in the hot Greek summer. -> A full set of AE111 ITBs ![]() Here's a teaser (love at first sight :wink ![]() |
03-28-2007, 01:56 PM
Post: #216
Keep the T50 even with broken parts inside.
03-28-2007, 01:59 PM
Post: #217
I wouldn't throw it away jamie. But knowing TOYOTA, the cost of the primary shaft could cost me more than a tip-top condition used gearbox.
03-28-2007, 02:56 PM
Post: #218
You best friend here sais:
1) Listen to jammiemirror 2) DO install the AC when ready 3) Put the ITBs on with an aftermarket ECU (I can find e-manage for cheap, you know) danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
03-28-2007, 03:49 PM
Post: #219
As I said, I would not throw it away anyway. I would just like to know if there's more to jamie's rationale than the obvious (we never throw something that heavy and expensive away).
03-28-2007, 03:56 PM
Post: #220
Yes, there is reason.
I bought "damaged" (but it seems OK!) T50 in order to try to convert it to custom ratio and try dogbox also. But I have more important job to do at the moment. If this experiment succeed, I hope prices will be far under Toyota/TRD ones. But such gear set will require T50 castings - remember ? ![]() |
Full restoration... | Blade1988 | 64 | 86,647 |
07-17-2016 11:53 AM Last Post: McGlinchey |
Another danish restoration | Duze | 61 | 73,703 |
03-20-2016 08:58 AM Last Post: Duze |
'84 ae86 restoration project | HybriD07 | 19 | 25,788 |
10-13-2014 09:20 PM Last Post: HybriD07 |
TOYOTA COROLLA Ke70 - Restoration project | cke70 | 34 | 52,076 |
07-02-2014 10:12 PM Last Post: cke70 |
Black Limited restoration | slpery86 | 6 | 10,112 |
12-17-2013 09:22 PM Last Post: banpei |
