Grooved discs and Ferodo DS pads
03-11-2008, 11:15 PM
I'd say both are really good, but mintex has the bites-from-cold advantage for streetdriving, whilst the ds2500's are the kind of pad I would only use for trackdays since they dont bite too well before they are warmed up a bit.
03-11-2008, 11:57 PM
I've just tried the DS3000 (Ferodo) and found them more agressiv than the DS2500. But wheels lock easier too .
The bad point of that , is that you need to cut pads to have the AE86 caliper shape ( about 3 hours of work) , but it's worth to do it . Filh Filh Save the RWD cars |
03-16-2008, 09:28 PM
Hey Rik I have some grooved/drilled discs, or just drilled...
03-16-2008, 10:07 PM
20vWill Wrote:Hey Rik I have some grooved/drilled discs, or just drilled... Hi Will Only want grooved, not grooved and drilled. They do not last on Spa at all :-) Thnaks anyway dude! BTW, looking for a 20V engien WH, or at least all the connectors, have any? |
03-16-2008, 10:49 PM
rikard Wrote:Only want grooved, not grooved and drilled. They do not last on Spa at all :-) Sorry to interrupt this topic but i would like to know why grooved and drilled are not good and grooved is good... very currious because i have to change my discs before next MOT 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
03-16-2008, 11:25 PM
DJexor Wrote:rikard Wrote:Only want grooved, not grooved and drilled. They do not last on Spa at all :-) I have had many drilled discs crack because of heat. The only ones I have not seen crack are the porsche discs because the holes are cast into the disk during manufacturing and not drilled after they are manufactured. |
03-16-2008, 11:28 PM
rikard Wrote:I have had many drilled discs crack because of heat. The only ones I have not seen crack are the porsche discs because the holes are cast into the disk during manufacturing and not drilled after they are manufactured. Aah good to know that! Thanks man! 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
03-17-2008, 01:04 PM
No wiring sorry Rik.
Fensport sell grooved black diamond discs but they are expensive. |
Handbrake adjustment discs? | DMC | 8 | 1,671 |
03-10-2024 08:08 PM Last Post: DMC |
Problems Mintex M1155 pads | Dino86 | 9 | 8,753 |
Brake PADS:) | Mux213 | 32 | 42,436 |
11-08-2016 04:55 PM Last Post: pack |
Brake Pads | |BUDA| | 8 | 10,297 |
04-16-2013 08:30 PM Last Post: damusto |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 5,805 |
