HELP! Flywheel 'step' height - Look here!
04-21-2006, 03:45 PM
Hi Guys,
i gave my flywheel to be machined, but the idiots machined only the part which gets in contact with the clutch ..... rather than taking off the same amount in both areas
the guy who did it was long gone when i arrived to pick it up, and they dont know how much he 'took off' so
has ANYONE got a flywheel out of their car???
I need the measurement of the 'step' - where the pressure plate bolts on and the surface which goes into contact with the clutch.
So if you can help me out, before 18:00 it would be very good...
EDIT:
i have circled in red what I'm talking about...i need the measurement of that little width difference
[Image: AEU86 AE86 - HELP! Flywheel 'step' height - Look here!]
Koukis - Red, Silver/Gray,
04-21-2006, 04:56 PM
SMS me around 17:45
my gsm is +385 91 3015 822
I will be at home then.
BR
ZaX
  light weight Flywheel filh 9 7,393 02-05-2018 05:20 PM
Last Post: filh
  crank 6 bolt flywheel DJexor 5 8,180 12-05-2016 08:21 AM
Last Post: d3nso
  Flywheel fitting totta Crolla 11 12,894 11-24-2013 05:31 PM
Last Post: Apsogos
  Gear end , drive pinion height filh 5 11,309 06-27-2013 12:29 AM
Last Post: filh
  Flywheel and clutch kit 86Pilot 1 3,514 12-01-2011 01:26 PM
Last Post: 86Pilot
