HELP! Flywheel 'step' height - Look here!
04-21-2006, 03:45 PM
Hi Guys,
i gave my flywheel to be machined, but the idiots machined only the part which gets in contact with the clutch ..... rather than taking off the same amount in both areas the guy who did it was long gone when i arrived to pick it up, and they dont know how much he 'took off' so has ANYONE got a flywheel out of their car??? I need the measurement of the 'step' - where the pressure plate bolts on and the surface which goes into contact with the clutch. So if you can help me out, before 18:00 it would be very good... EDIT: i have circled in red what I'm talking about...i need the measurement of that little width difference ![]() Always remember: Rev it till it blows, then back off a bit... Zenkis - Orange, Red/Black, Silver/Black, Maroon/Blue Koukis - Red, Silver/Gray, |
04-21-2006, 04:56 PM
SMS me around 17:45
my gsm is +385 91 3015 822 I will be at home then. BR ZaX Drifting - best fun you can have in your car with your pants on! |
light weight Flywheel | filh | 9 | 7,407 |
02-05-2018 05:20 PM Last Post: filh |
crank 6 bolt flywheel | DJexor | 5 | 8,200 |
12-05-2016 08:21 AM Last Post: d3nso |
Flywheel fitting | totta Crolla | 11 | 12,900 |
11-24-2013 05:31 PM Last Post: Apsogos |
Gear end , drive pinion height | filh | 5 | 11,323 |
06-27-2013 12:29 AM Last Post: filh |
Flywheel and clutch kit | 86Pilot | 1 | 3,518 |
12-01-2011 01:26 PM Last Post: 86Pilot |
