[HELP] - Interior Back Door Opening
08-19-2007, 09:05 PM
Hi,
As i'm fitting a TRD spoiler in my Levin i have eliminated the back door opening button/key hole. I'm planning to install an interior lever to open the back door from inside, similar to the ones that are fit in newer Corolla and Carina E. However i need to know where i have to fit the steel cable in the back door in order to open the door when i pull the lever. Do i have to buy a new back door lock? Is mine different from the GTS Levin that has this lever fitted from factory? For example my Evo VI has an interior lever for the back door but it pulls the lock from the upper side (trunk door) but i think in the GTS Levin it pulls from the lowe side (body). Any pics from how this system works in an AE86? Thank you very much. Keeping the AE86 alive! |
08-20-2007, 07:58 AM
Unfortunately no pics, but I compared my lock with Mux some time ago to see if it were possible to fit a cable on his bootlock. There was no difference between the locks. The cable could be attached to his lock as well. However this was on two coupes, dunno if the hatchback features the same lock.
![]() Someone has a picture of a hatchback lock then? ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
08-20-2007, 08:46 PM
Well, the P/N is different.
There's a P/N for "normal" 3 door vehicles and another for vehicles with trunk opener (only the body part, the boot part is the same) Keeping the AE86 alive! |
08-22-2007, 02:44 PM
Correction:
The P/N used to be diferent but "now" the P/N is the same for either vehicles with trunk opener or without. P/N: 69430-12180 Keeping the AE86 alive! |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,283 |
04-25-2022 04:25 PM Last Post: gh0st |
Help needed with door mirror glasses | T_AE86 | 3 | 5,274 |
06-29-2013 01:16 AM Last Post: T_AE86 |
back camber of CBY | roiz86 | 5 | 9,105 |
03-24-2013 02:00 PM Last Post: roiz86 |
Removing interior plastics | Jezza_hr | 3 | 5,694 |
03-18-2013 11:41 PM Last Post: Ivan141 |
TE71: 2T-B engine thermostat opening temperature ? | Ryo | 1 | 3,687 |
04-06-2011 07:28 PM Last Post: Ryo |
