Changing distributor when carb 4age
07-01-2016, 04:45 PM
I have two options: going carb or 20v black top. I don't know what choose.
07-01-2016, 06:19 PM
Why wasting time with carbs when you already got a EFI setup? What are your goals for the motor? I wouldn't recomend swapping a 20V as for the same money you spent on the swap you will get the 16V faster
![]() Daily Beater: Civic EG5 Work in progress Car: AE86 |
07-04-2016, 10:07 AM
There are so many people feel overvhelming urge to change something... anything..
07-04-2016, 03:02 PM
I would go for the 20V because once it is swapped it is a lot easier to maintain.... the carbs are more troublesome....
07-04-2016, 03:27 PM
Got that right.. "once it's swapped"
![]() I would leave 16V and stock ECU if changes are not that big. If they are, standalone ECU, after all, if changes are big, that ain't gona be street car any more. |
Carb question please help | MIGGZFSU | 3 | 5,329 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
16v distributor hole plug | harkes | 8 | 10,380 |
Carb conversion but what is this and how ? | Allexz | 5 | 9,203 |
05-24-2016 08:48 AM Last Post: Allexz |
Distributor position and cranking | pack | 13 | 21,149 |
07-01-2013 11:08 PM Last Post: pack |
Mikuni carb help just wont balance | megabob | 3 | 5,660 |
01-01-2013 10:32 PM Last Post: allencr |
