HOWTO: Mazda FC3S 4pot Calipers
07-01-2005, 11:00 AM
You know I hate working.
Someone plz make the brackets and all necessary stuff,
and i'll just go buy the rx callipers and disks
I 'll buy the package if someones make like bolt on style Smile
p.s NICE TO HAVE YOU HERE HENS
[Image: AEU86 AE86 - HOWTO: Mazda FC3S 4pot Calipers] http://www.jdmbits.com
07-01-2005, 11:05 AM
nmwisima Wrote:You know I hate working.
As we are in Europe - in future I will offer only BMW/Volvo 4-pot calipers/adapter plates as kit ! :wink: But first - let test one in my car.
07-02-2005, 10:16 AM
That's amazing. You're the man Hen and Ian! Big thanks for both of you! Thumbs up!
07-02-2005, 11:16 AM
Sounds like a good plan Jamie..The volvo 4 pot girling callipers are f*ing huge (but all aloy so not to heavy). Lots of other cars used the same callipers, so pad selection is plentifull. Having to slow down a volvo that weighs a 3 tons also means that they have plenty of heat capacity, certainly more then the FC callipers.
Maybe it would be good to also take a look at the rear callipers. A switch to E30 BMW callipers could be a cheap upgrade that would improve capacity somewhat, but, more important, totally open up the choice of pads.
07-02-2005, 11:26 AM
2 Ivan141:
Quote:Maybe it would be good to also take a look at the rear callipers. A switch to E30 BMW callipers could be a cheap upgrade that would improve capacity somewhat, but, more important, totally open up the choice of pads.
I compared BMW E23 728 rear calipers and pads to the AE86 ones.
The BMW pads have smaller friction area ! They haven't e-brake mechanism also (E23 uses drums for e-brakes!). I have a little strange way to modify rears - using Wartburg 353W fronts (4-pot but with solid discs!!!) - but this is exotic and will not be useful with conventional e-brake. I found some 2-pot rears in Opels so maybe this is the right modification for rear brakes - cheap and widely available ?
07-02-2005, 02:52 PM
Hi Hen,
thankyou for coming to join aeu86.org - we are a good bunch and thankyou very much for taking the trouble to design the brackets.
Regards Ian.
07-02-2005, 05:06 PM
Thanks for all the comments guys. I bought a pair of FC calipers years ago without realising how hard they would be to fit. So I thought anyone in the same boat might want to know my results.
As for rear brakes, if you have a T series rear end (not sure what models you got in Europe, in Oz we got an S series (crap) rear end) then the entire disc assembly fron an RT141 Corona bolts on. Reasonable sized discs with an internal drum handbrake (good for rally/drift). Only modification is that the shock mounts on the diff need to be moved in about 10mm.
Hen
No, this thing is totally stock standard officer...
07-02-2005, 09:49 PM
Hen,
i have never seen a corona rt141 in Holland.. ( maybe some other dutch here??)
i see a lot of older nice japanese cars driven in australia that are here only in a museum.. ( like older corolla's, or cars like the mazda Rx3,Rx4. R100. often they used it for the dragsports.. http://www.fullboost.com.au in australia)
and are the adapterplates made for the original brakedisks? or is it posible to fit rx7 disks?? ( wich disks have you mounted?)
thanx again Thumbs up! !!
Toyota Starlet 1994
Mitsubishi Space wagon 2.4 1999
ex Ae86 owner
07-03-2005, 01:21 PM
AndrE86 Wrote:Hen,
No, I thought the corona stopped here after the Mark II. Undecided
07-03-2005, 01:51 PM
Do not forget more is not better. Bigger calipers and bigger disks means more weight. You have to find the balance. The FC 4-pot are alu so maybe they are not even heavier than OEM calipers. Getting 4-pot rears is just silly overkill. I think you only need to do the front.
Broken down 1984 Trueno HB
  Brake calipers identification FanIsHere 4 4,189 10-23-2020 11:45 PM
Last Post: FanIsHere
  RX7 Calipers with Rota Grid V ET0 15x8' pack 11 13,405 02-06-2015 11:28 AM
  4 pot rx7 calipers Petros AE86 17 18,304 02-20-2012 09:39 PM
Last Post: Jimmi The Kid
  Golf Mk4-AudiA4 calipers on rear Dino86 3 5,327 11-02-2011 05:30 PM
Last Post: filh
  mazda rx7 wheels Roger 2 4,212 05-27-2011 05:45 PM
Last Post: Roger
