Head gasket
05-23-2008, 10:09 PM
Head gasket
Time has come to change the head gasket on my bluetop Huh
I wondered if it is necessary to remove the inlet/TVIS system, should it definately need to come off can anyone give me a tip on undoing the bolts underneath Confused
Also I need to buy a socket to fit the head bolts, what size do I need ?
Many thanks,
TC
05-25-2008, 12:30 PM
Head gasket
A 12 sided 12mm impact socket (a good one) for the head bolts.
and i have done my head before without taking the intake manifold off at all, just have to disconnect all the loom and vacuum/coolant line before you attempt to lift it.
05-25-2008, 12:34 PM
Head gasket
And it is no harder getting at the TVIS connector than it is at the manifold bolts......
Be very careful not to damage that. Especially, do NOT be tempted to pull off the vacuum tube from the TVIS VSV when it is still bolted to the engine as you WILL end up breaking off the nipple it locates on.
05-25-2008, 09:18 PM
Head gasket
Parrot is absolutely right. I have girlish arms and its still hard for me to get underneath, so good luck.
F0B
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
05-26-2008, 01:30 AM
Head gasket
Some of them you need to get at by climbing up underneath as much as possible. A couple can be best got at with some long extension bars. Whatever, take your time to reduce the chance of rounding them off. It is not a fun job.
But yes, it is a good idea to take the plenum off intact with the head. But as above, remember to unclip the TVIS VSV connecter first.
05-27-2008, 08:01 AM
Head gasket
Hey, sorry to just jump in but...
The car I'm looking at has a blown head gasket, or at least thats as much as the previous owner knows, and I don't have lots of mechanical experience. I found the manual for torque specifications and order and have knowledgeable friends willing to help me out but I just wanted to make sure I had everything I needed. Obviously a new head gasket... possibly new head bolts or anything else?
thanks for any replies.
hopefully the head isn't warped Huh
05-29-2008, 05:46 AM
Head gasket
Definitely new head bolts, water pump, tensioner bearing, valve cover seals and grommets.
05-30-2008, 10:13 PM
Head gasket
Head off now !
Not too bad really, I used an extension bar as suggested above, thanks.
Ikedude, might be a good idea to replace the distributor 'o'ring and the two on the short pipe that joins the water pump to the head. All available from Toyota.
05-31-2008, 09:52 AM
Head gasket
Alright, thanks for the help. When you say available from Toyota, you mean ordering through a dealership? Sorry if this is obvious but I've never done that.
05-31-2008, 08:31 PM
Head gasket
Ikedude Wrote:Alright, thanks for the help. When you say available from Toyota, you mean ordering through a dealership? Sorry if this is obvious but I've never done that.
Yes Thumbs up!
  Oil leak (maybe a cylinder head gasket?) max_ae86 15 17,248 11-30-2013 03:59 AM
Last Post: jondee86
  4AGE Heat Shielding Intake Gasket asyrigos 11 23,978 04-01-2013 10:58 AM
Last Post: asyrigos
  Doing a 7AGE build, gasket question Snejk 9 14,299 07-15-2010 12:42 PM
Last Post: PetzK
  Head Gasket Replacement - Block Surface Question ?? juantonwan 4 5,604 06-11-2009 02:24 PM
Last Post: ZDoman
  oem head gasket thickness? Melo 6 5,979 05-22-2009 10:46 PM
Last Post: Melo
User(s) browsing this thread: 15 Guest(s)
