Header + exhaust for Beams setup
09-27-2011, 03:22 PM
Any advise?
Looking for a 4-2-1 + mid pipe + exhaust to fit to the beams. I believe there should be no off the shelf item and need to go for custom. But at least I need the advise for the 4-2-1 header and I think I can manage to get the mid pipe and exhaust custom made. Please share your idea. Thanks, Yung |
09-27-2011, 09:29 PM
How large an exhaust diameter do you need? I assume this is for an AE86?? I know of 2 full size muffler exhausts(over axle) that use 60mm diameter piping. One is Kakimoto R - http://www.kakimotoracing.co.jp/image_ts332.html Cost: about 75000 yen
![]() The other would be Brave - http://www5f.biglobe.ne.jp/~brave-nh/pro...-list.html - look for BRMT028 Cost: about 39800 yen ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-28-2011, 02:57 AM
It is for my 86 and currently installing a Beams on it, so need a different exhaust.
I would like to go for a standard dia now, not sure if the standard one for Beams is 60mm? I have the stock header now but apparently it is too low and nearily touch the ground. Wondering should I go for a after makert 4-2-1 header or just modify the stock one to fit a custom make down pipe then so on. |
09-29-2011, 03:45 PM
So, does anyone know if the stock exhaust for beam is 60mm dia?
Thanks in advance. |
10-02-2011, 06:59 AM
Header + exhaust for Beams setup | |||
10-02-2011, 06:15 PM
Thanks Andrew!
I think I will go for a 86 - 60mm mid to exhaust and modify the header to fit it. I believe you do the same in your car, right? Cheers! ![]() |
10-02-2011, 07:42 PM
KD2229 Wrote:Thanks Andrew! I'm running the Brave in my car... :wink: http://s79.photobucket.com/albums/j143/o...peview.mp4 Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-03-2011, 07:25 AM
Dan,
You've got PM. |
4 Link setup and Traction brackets | Jezza_hr | 5 | 10,593 |
07-21-2014 09:12 PM Last Post: Bean |
Toyota KE70 3SGE Beams Swap - Axle reliability | cke70 | 15 | 26,527 |
04-13-2014 12:49 PM Last Post: Celica RA45 |
Wanted: Link to Beams Blacktop engine manual pdf | irishtwincam | 7 | 9,126 |
01-03-2014 11:31 AM Last Post: irishtwincam |
20v 4age header | Alex170984 | 5 | 7,890 |
10-30-2013 12:53 AM Last Post: fax0815 |
DIV 1 rally/track suspension setup | ditn | 60 | 75,088 |
03-28-2013 11:28 PM Last Post: ditn |
