Heater Light ?
12-28-2004, 01:22 AM
Heater Light ?
My heater console does not light up. I had the same problem with the light surrounding the lighter and have found the blown bulb for this.
Does anyone know where the bulb for the heater console is ? The rest of the dashboard lights up (speedo, revs etc etc) |
12-28-2004, 01:34 AM
Heater Light ?
Ain't it somewhere in the footwell? If you don't know the position of the fuse just check all of them.
12-28-2004, 01:36 AM
Heater Light ?
the fuses are fine, i think its the actual bulb. Does it even have a bulb ?
12-28-2004, 01:37 AM
Heater Light ?
Its a light system like your dashboard (speedo meter etc) you will have to remove the console and remove the panel
12-28-2004, 02:22 AM
Heater Light ?
I have removed that panel once, the lighting should be integrated into the heater controls..
I shorted the wires of the heater lighting once, trying to tap a lighting source for my oil temp gauge, and it wouldnt light up for a few weeks. Strangely enough it started working again after a while...You need to take of quite a bit of dashboard to be able to get to that panel though, I would advise you to remember the assembly order very well since it is sometimes slightly confusing. FABRICA MI DIEM, PVNC! |
AE86 Heater Control Light | Super86 | 8 | 9,360 |
07-20-2016 07:22 AM Last Post: Super86 |
Carina TA62 / TA60 heater blower stopped working | Bushido | 9 | 11,355 |
11-14-2014 12:57 AM Last Post: Bushido |
Heater issue | Jezza_hr | 9 | 13,265 |
10-02-2014 07:51 PM Last Post: Jezza_hr |
Heater blower removal | phill 92 | 2 | 4,293 |
12-13-2012 10:55 AM Last Post: allencr |
Leaky heater control valve? | phill 92 | 1 | 3,577 |
03-13-2012 05:40 PM Last Post: phill 92 |
