Help me add some hose power to my ae86!
12-03-2008, 05:08 AM
I have an 84 ae86 with a 4AC engine and an automatic transmission. I'm eventually going to be swapping the engine, but for now I'd like to see how many horsepower I can get out of my 4ac. Any ideas? I'm trying to keep the spending to a minimum. Thanks.
12-03-2008, 06:01 PM
You could start with fitting a different carb and/or cam on the 4ac:
http://www.paradiseracing.com/cams.htm http://www.paradiseracing.com/carbs.htm I thought they had 4ac turbo kit in the past, however I could not find it on their site. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
12-04-2008, 03:14 AM
Turbo works, but can be a little bit unreliable. If you're adapting your own gear, make it suck through (carby before the turbo). Have a look at old (carby) charged setups.
A guy in Australia said he got good results from a cam regrind and a larger carby. First things first though, make sure your engine is in good condition, filters, timing, compression, spark. A cold air induction would probably help and for the cost of some pvc/flex pipe, it's a cheap option. They're hard to kill and easily/cheaply (free) replaced, so have fun playing around and save for the 4age. Chris |
Some wiring help needed | DJexor | 5 | 5,755 |
Need some help | DJexor | 4 | 5,618 |
03-13-2018 05:37 PM Last Post: pack |
fuel line hose from the pump | Wikizz | 4 | 6,263 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
cool lower radiator hose | thanos | 4 | 5,745 |
AE86 non-power steering problem | andee17 | 3 | 7,527 |
07-25-2013 06:41 AM Last Post: jondee86 |
User(s) browsing this thread:
