Help me add some hose power to my ae86!
12-03-2008, 05:08 AM
I have an 84 ae86 with a 4AC engine and an automatic transmission. I'm eventually going to be swapping the engine, but for now I'd like to see how many horsepower I can get out of my 4ac. Any ideas? I'm trying to keep the spending to a minimum. Thanks.
12-03-2008, 06:01 PM
You could start with fitting a different carb and/or cam on the 4ac:
http://www.paradiseracing.com/cams.htm
http://www.paradiseracing.com/carbs.htm
I thought they had 4ac turbo kit in the past, however I could not find it on their site.
[Image: AEU86 AE86 - Help me add some hose power to my ae86!]
12-04-2008, 03:14 AM
Turbo works, but can be a little bit unreliable. If you're adapting your own gear, make it suck through (carby before the turbo). Have a look at old (carby) charged setups.
A guy in Australia said he got good results from a cam regrind and a larger carby.
First things first though, make sure your engine is in good condition, filters, timing, compression, spark.
A cold air induction would probably help and for the cost of some pvc/flex pipe, it's a cheap option.
They're hard to kill and easily/cheaply (free) replaced, so have fun playing around and save for the 4age.
Chris
  Some wiring help needed DJexor 5 5,806 05-18-2019 01:50 PM
Last Post: DJexor
  Need some help DJexor 4 5,656 03-13-2018 05:37 PM
Last Post: pack
  fuel line hose from the pump Wikizz 4 6,306 10-16-2017 07:11 PM
Last Post: jdm86gtz
  cool lower radiator hose thanos 4 5,778 11-29-2016 01:06 PM
Last Post: thanos
  AE86 non-power steering problem andee17 3 7,563 07-25-2013 06:41 AM
Last Post: jondee86
User(s) browsing this thread:
