High oil pressure
10-19-2005, 10:52 AM
Ivan141 Wrote:Uhm..no...there is a 1cm thick rubber pipe coming from the valve covers going to the middle of the intake manifold. You need to pull this loose while the engine is running (I would the pull hose off on the manifold side).
Just put your thumb on it and see how much pressure it builds up. Also give it a bit of throttle (by pulling the throttle lever off course) and see if it blows out much smoke. If you get lots of pressure, and lots of smoke then you can be certain that some piston rings have broken. If it's not blowing hard from the ventilation hose then it's probably fine.
The best 4AGE I have ever seen had almost no air blowing out of the PCV (crankcase ventilation) and ran smoothly and quitly at 500 rpm, so it is a pretty good indicator of the state of the engine.
Hey Ivan thanks! I did what you told me and there was a lot of pressure coming out of the valve covers, but there wasn't any smoke.
I'm now testing the oil consumption. Drove 550 km and almost as much oil in it as before.. Lets test it at 1000km.
[Image: AEU86 AE86 -  ]
Messages In This Thread
High oil pressure - DJexor - 10-13-2005, 12:25 PM
[] - @dodo@ - 10-13-2005, 12:34 PM
[] - lasse - 10-13-2005, 01:03 PM
[] - Ivan141 - 10-13-2005, 01:10 PM
[] - max_ae86 - 10-13-2005, 01:27 PM
[] - Ivan141 - 10-13-2005, 01:39 PM
[] - max_ae86 - 10-13-2005, 02:31 PM
[] - DJexor - 10-13-2005, 03:11 PM
[] - The Doctor - 10-13-2005, 03:16 PM
[] - DJexor - 10-13-2005, 03:42 PM
[] - Ivan141 - 10-13-2005, 03:51 PM
[] - The Doctor - 10-13-2005, 04:08 PM
[] - Kas - 10-13-2005, 04:36 PM
[] - Ivan141 - 10-14-2005, 07:29 AM
[] - DJexor - 10-14-2005, 09:26 AM
[] - Ivan141 - 10-14-2005, 09:37 AM
[] - wouter86 - 10-16-2005, 05:08 PM
[] - banpei - 10-16-2005, 09:29 PM
[] - wouter86 - 10-16-2005, 10:11 PM
[] - DJexor - 10-19-2005, 10:48 AM
[] - DJexor - 10-19-2005 10:52 AM
  High-beam warning lamp Mylesmck 4 1,386 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 2,347 08-30-2022 07:11 PM
Last Post: Power_uP
  4AGE 16V engine overheat when at high speed chenfon 32 20,776 12-31-2020 06:39 AM
Last Post: chenfon
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 20,774 08-19-2018 12:08 PM
Last Post: AlexKTM
  Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) Rascal21 41 32,999 08-21-2016 04:51 PM
Last Post: ray
