High oil pressure
10-19-2005, 10:52 AM
High oil pressure
Ivan141 Wrote:Uhm..no...there is a 1cm thick rubber pipe coming from the valve covers going to the middle of the intake manifold. You need to pull this loose while the engine is running (I would the pull hose off on the manifold side). Hey Ivan thanks! I did what you told me and there was a lot of pressure coming out of the valve covers, but there wasn't any smoke. I'm now testing the oil consumption. Drove 550 km and almost as much oil in it as before.. Lets test it at 1000km. 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
High-beam warning lamp | Mylesmck | 4 | 1,289 |
07-21-2023 07:44 AM Last Post: banpei |
Engine stress at high speeds | gh0st | 6 | 2,244 |
08-30-2022 07:11 PM Last Post: Power_uP |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 20,238 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 20,455 |
Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) | Rascal21 | 41 | 32,188 |
08-21-2016 04:51 PM Last Post: ray |
