Hot IdleProblems
02-04-2006, 01:12 AM
Hot IdleProblems
Here's my recentley purchased '86 ae86 4age levin
[Image: AEU86 AE86 - Hot IdleProblems]
My problem is hot idle . when the engine is cold it revs fine at idle ( occasionly 2300 rpm , but pick the throttle and that settles out. ) when the engine reaches 45% on the scale and the engine is under no load ( neutral , no rear heated window ) the engine revs up and down between 700 and 1800 rpm this makes crawling in traffic difficult and sounds terrible too. ( grief from the missus ) if a load is put on the engine , half clutch or sometimes lights , heater & fans on, the idleing settles for a few mins.
i've checked coolant level , this was low but filled and no change. btw a sports air filter is fitted. i was told this could affect it. the valve cap in the throttle body was repalced with a tyre cap that didn't make any diff either. a friend mentioned it could be a leaky vaccuum pipe somewhere.
where and what should i check next ?
i'm still kinda green ya see. Wink
02-04-2006, 04:03 PM
Hot IdleProblems
any takers ?
02-04-2006, 06:28 PM
Hot IdleProblems
It sounds like the problem Oldskull also suffers from:
http://www.aeu86.org/viewtopic.php?t=2500
02-04-2006, 06:50 PM
Hot IdleProblems
TPS sensor is faulty.
Jón Mar
"T3 is good. I'd go with them. And they're red. Red goes faster..."
'87 AE86 3dr - Black
'87 AE86 3dr - Red
'88 AE92 5dr GTi - Black
'95 ST205 - Red - sold
03-05-2006, 10:11 PM
Hot IdleProblems
I had this problem on my MG Midget (4AGE installed). It was fine when engine cold, but when it warmed up it would hunt all over the place. I narrowed it down to the IAC valve under the throttle intake. I took it off and replaced it with a flat sheet of Aluminium, and just linked the two water pipes together, car now needs a few pumps of the throttle to get started and then takes a 30 secs before it will idle, but after that, not a problem.
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
03-06-2006, 03:00 AM
Hot IdleProblems
you can screw up your idle to 1k rpm which is fine. The screw is next to your intake!
04-02-2006, 10:04 AM
Hot IdleProblems
When my ae85 idles it is at about 500 - 550 rpm, this is far too low. sometimes when i am just sitting at the lights the car stalls itself which is very embarrasing (either people think i am a crappy driver or they know i have a bad car http://www.aeu86.org/viewtopic.php?p=41074#41074)
I figure that screwing up the idle should fix this but i dont know how, i dont have a 4 series engine either, it is a 3au. Can someone help me? i need to know what i am looking for and where it is to increase idle speed.
Current Cars:
'86 SE82 FX GT
'88 NZ New KE70 Van (Daily)
04-02-2006, 11:42 AM
Hot IdleProblems
I think carbs have some sort of idle air screw too. There are a few guys that know their way around those carbs here. You could try sending Ben a PM, his username is 1974KE25 around here, he usually knows his way around about every toyota there is.
  Engine cranks slowly when hot... but starts Dino86 9 14,513 02-03-2014 08:04 PM
Last Post: Dino86
  Hot oil filter - a problem? harkes 5 6,764 01-03-2014 09:33 PM
Last Post: Apsogos
  Hot Wheels Blue86 2 3,988 11-02-2010 02:19 AM
Last Post: JonnyAE86
  Wires getting hot! choco 8 7,682 11-23-2007 12:57 AM
Last Post: choco
