How To: DIY Short-Shifter
11-12-2004, 01:45 PM
Any of you more technicaly inclined people can help with a write up on how to make a short throw shifter? Would be very appreciated Smile
11-12-2004, 01:53 PM
i have made 2 as of now.
want the entire list of how to do one ?
NO problems.
11-12-2004, 03:05 PM
Dumb question please, I would like to know also
You have by far the ugliest hachi on the nicest rims in the world -Mux213
11-12-2004, 08:47 PM
Kristian,
I'm paying attention Cool
Regards Ian.
[Image: AEU86 AE86 - How To: DIY Short-Shifter]
11-12-2004, 09:16 PM
yeah, yeah we are still paying attentio Hurray! Hurray! Hurray! Hurray!
11-12-2004, 09:55 PM
step by step:
1: remove interiour around gearstick (shifter)
2: losen the 4 6mm (10mm tool) bolts that hold the rubber dust-protection-cover.
3: loosen the 4 8mm bolts that hold the gearstick to the gearbox.
4. lift up gearstick slowly in order to check if plastic cup at bottom of gearstick is loose. (replace plastic cup. about 5 Euro at Toyota.)
5: using hacksaw (metal-blade 1mm thick) cut gearstick 10mm above lower ball-joint.
6: cut metal tube of approximatly same diameter as gearstick to exactly 21mm lenght
7: lengthen gearstick using using MIG/TIG welder & after welding grind down welds to a minimum & reweld - this makes it stronger.
8: using upper gearstick mount - se picture take aluminum block in size 20x80x103mm, Place block below mount - drill the 4 8mm boltholes using 9/10mm drill.
9: using gearstick mount gasket (if not broken when removed) as a measurment (blueprint) take metalblock - measure the inner line & drill-out the center so that it copy´s the gasket.
10: make one more gasket using stock gasket as blueprint.
11: re-assemble
12: you now have 55% shorter throw to your gears.
.....Kristian
gearshift mount... se below.
12-02-2004, 10:25 PM
new pics added
12-03-2004, 12:29 AM
nice one :-) don't understand it fully yet but hey will come in time
01-05-2005, 02:38 PM
A simplest way to short shifting :-)
01-05-2005, 02:49 PM
2 jamiemirro: To me it looks just like a cutted gearstick.
Kris has posted correct way to make short throw shifter for faster shifting.
  TRD Short Shifter Rattle Noise, It's Normal? Mattolo 19 20,021 04-27-2024 10:04 PM
  DIY: a quick outline on why & how to set pinion angle. assassin10000 9 18,615 12-21-2016 10:28 PM
Last Post: ditn
  Anyone running DIY Coilovers? Rasteirinho 8 13,781 11-19-2013 10:30 PM
Last Post: totta Crolla
  Were to find 4AG-ZE gaskets in toyota diy? fax0815 17 15,987 05-28-2013 10:17 PM
Last Post: ditn
  DIY Coilover sketchy 8 13,073 04-01-2013 11:00 PM
Last Post: sketchy
User(s) browsing this thread: 19 Guest(s)
