How do i fit a Oil Catch can to a 16v 4age??
04-17-2006, 06:30 AM
im new here and im from Australia..
i have a levin Coupe.. any help guys?? can anyone explain it to me.. as noone i speak to seems to give me a straight answer.. thanks |
04-17-2006, 09:54 AM
Oil catch tank is pretty simple think to instal.
1. Find a good spot (that must be away from the exhaust manifold and extensive heat) 2. Mount it. 3. There is an oil hose going to your intake where the throttle is, find it and see where it goes (it goes on top of the engine) 4. Go and buy some more hose (meassure how much you need) 5. Connect the throttle outlet to one of the tanks inlets and from the engine outlet out the other tank inlet. Thats it Alternatively, you can close the engine outlet entirely, and put a small oil breath filter to the tank. danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
04-17-2006, 11:03 AM
nmwisima Wrote:Alternatively, you can close the engine outlet entirely, and put a small oil breath filter to the tank. ...but...if you close the engine outlet entirely....how will the catch tank fill with oil? :roll: |
04-17-2006, 12:16 PM
Quote:...but...if you close the engine outlet entirely....how will the catch tank fill with oil? ![]() ![]() 1987 AE86 http://www.bilgalleri.dk/html/gal_visbil.asp?ID=41755 http://www.aeu86.org/forum/viewtopic.php?t=3255 ...FWD SUCKS!!... |
04-17-2006, 12:28 PM
Yeah right, I wish Pumkingking isnt that quick technician
![]() ![]() ![]() danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
04-21-2006, 01:31 PM
Pardon me for this question but what for is used this oil cath can and why to use it? I newer asked about this
![]() 85' AE86 GT coupe lifetime project since 2005 |
04-21-2006, 01:47 PM
Ryo Wrote:Pardon me for this question but what for is used this oil cath can and why to use it? I newer asked about this If you prefer not to collect all these oil vapours on your throttle body and burn them in your engine - you must use oil catch can (or just small filter at the end of tube instead to open it directly to the atmosphere). |
04-21-2006, 01:53 PM
You can do a little experiment: take your car and start driving in a circle (lefthand turn), then pick up some speed. Keep it up for a few rounds and have a look in the rearview mirror. Do make sure you have enough oil in your engine before you start doing this.
04-26-2006, 01:37 PM
Hmm understand now for what purpose it's used. Ok is there somewhere more info about installation of oil catch can into the hachi. If yes please give me some link, thanks.
Btw what i will see in the rear mirror after i do that ![]() 85' AE86 GT coupe lifetime project since 2005 |
04-26-2006, 01:53 PM
Ryo Wrote:Btw what i will see in the rear mirror after i do thatThe correct answer should be: a smokescreen. Really there isnt such a thing as an install guideline afaik. You need a container with an inlet and outlet, some hose and thats it. You mount the can anywhere you can find enough room, then you just remove the little hose from the head to the inlet manifold and replace it with 2 long rubber hoses going to your catchcan. Couldnt be much simpler. A catchcan is not really necessary on a roadcar, but has it's uses for drifting and trackdriving. Some people have reported the smoking problem to have happened on long highway turns, but I have never experienced that myself. FABRICA MI DIEM, PVNC! |
Can Wing Mirror Glass be Replaced? | chrisae86 | 1 | 1,676 |
03-05-2023 09:34 PM Last Post: Ivan141 |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,878 |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 10,479 |
12-19-2021 11:58 PM Last Post: gh0st |
Mistlamps don't fit | gh0st | 1 | 2,692 |
10-14-2021 09:00 PM Last Post: banpei |
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 12,085 |
