How do i fit a Oil Catch can to a 16v 4age??
04-17-2006, 06:30 AM
im new here and im from Australia..
i have a levin Coupe..
any help guys?? can anyone explain it to me.. as noone i speak to seems to give me a straight answer..
thanks
04-17-2006, 09:54 AM
Oil catch tank is pretty simple think to instal.
1. Find a good spot (that must be away from the exhaust manifold and extensive heat)
2. Mount it.
3. There is an oil hose going to your intake where the throttle is, find it and see where it goes (it goes on top of the engine)
4. Go and buy some more hose (meassure how much you need)
5. Connect the throttle outlet to one of the tanks inlets and from the engine outlet out the other tank inlet.
Thats it
Alternatively, you can close the engine outlet entirely, and put a small oil breath filter to the tank.
[Image: AEU86 AE86 - How do i fit a Oil Catch ca...16v 4age??] http://www.jdmbits.com
04-17-2006, 11:03 AM
nmwisima Wrote:Alternatively, you can close the engine outlet entirely, and put a small oil breath filter to the tank.
...but...if you close the engine outlet entirely....how will the catch tank fill with oil? :roll:
04-17-2006, 12:16 PM
Quote:...but...if you close the engine outlet entirely....how will the catch tank fill with oil?
Big Grin haha.. yes dont close of the engine outlet... thats were the crankshaft breathing is... and its that outlet/vent you want to direct to your catchtank instead of your intake manifold.. In that way you wont get any oil "recycled" through your intake manifold/combustion.
1987 AE86
http://www.bilgalleri.dk/html/gal_visbil.asp?ID=41755
http://www.aeu86.org/forum/viewtopic.php?t=3255
...FWD SUCKS!!...
04-17-2006, 12:28 PM
Yeah right, I wish Pumkingking isnt that quick technician Big Grin Big Grin Big Grin
04-21-2006, 01:31 PM
Pardon me for this question but what for is used this oil cath can and why to use it? I newer asked about this Tongue
85' AE86 GT coupe lifetime project since 2005
04-21-2006, 01:47 PM
Ryo Wrote:Pardon me for this question but what for is used this oil cath can and why to use it? I newer asked about this Tongue
If you prefer not to collect all these oil vapours on your throttle body and burn them in your engine - you must use oil catch can (or just small filter at the end of tube instead to open it directly to the atmosphere).
04-21-2006, 01:53 PM
You can do a little experiment: take your car and start driving in a circle (lefthand turn), then pick up some speed. Keep it up for a few rounds and have a look in the rearview mirror. Do make sure you have enough oil in your engine before you start doing this.
04-26-2006, 01:37 PM
Hmm understand now for what purpose it's used. Ok is there somewhere more info about installation of oil catch can into the hachi. If yes please give me some link, thanks.
Btw what i will see in the rear mirror after i do that Tongue ?
04-26-2006, 01:53 PM
Ryo Wrote:Btw what i will see in the rear mirror after i do that Tongue ?
The correct answer should be: a smokescreen.
Really there isnt such a thing as an install guideline afaik. You need a container with an inlet and outlet, some hose and thats it. You mount the can anywhere you can find enough room, then you just remove the little hose from the head to the inlet manifold and replace it with 2 long rubber hoses going to your catchcan. Couldnt be much simpler. A catchcan is not really necessary on a roadcar, but has it's uses for drifting and trackdriving. Some people have reported the smoking problem to have happened on long highway turns, but I have never experienced that myself.
Wink Can Wing Mirror Glass be Replaced? chrisae86 1 1,204 03-05-2023 09:34 PM
  Can you convert your 86 back too the original state? gh0st 7 3,023 04-25-2022 04:25 PM
Last Post: gh0st
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 8,201 12-19-2021 11:58 PM
Last Post: gh0st
  Mistlamps don't fit gh0st 1 2,305 10-14-2021 09:00 PM
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,527 09-08-2021 12:48 PM
Last Post: Ryo
