How to: Front brake lines.
01-08-2005, 08:21 PM
Ok, time to change brake lines? Here we go!
![]() First, get a can or bottle that you can drip the old brake oil into so that you dont't make too much mess. 1. Remove the upper mount of the brake line, 10 mm: ![]() 2. Pull out the U-shaped pin that holds the brake line in the mount, easily done with a polygrip: ![]() ![]() 3. The mount on the front damper. I think there should be a U-shaped pin holding it here too, but there wasn't on mine. Then i just bent the mount carefully so that i could remove the brake line. ![]() 4. The final, 17mm. Just unscrew it. (Oooh! look at my new fresch beautiful bushings! ![]() ![]() 5. Go get your new fresch brake lines and repeat in reverse. ![]() The upper mount can be quite difficult with the both pins, there are a small one on your brake lines (i forgot to take a picture of it..) and the U-shaped one you pulled out earlier. I put both the pins on just little then used a hammer to get them both in place. The U-shaped pin go over the mount, the small other one below. ![]() Finished result! Now just repeat on the other side and don't forget the new brake oil and bleed the brakes! ![]() Hope that someone get help from this! Best Regards, ![]() |
01-08-2005, 08:54 PM
You mean 'bleeding' the brakes.
01-08-2005, 08:55 PM
Aico Wrote:You mean 'bleeding' the brakes.Yeah! Thanks ![]() ![]() |
01-08-2005, 11:46 PM
Warning!
Your master brake cylinder must mu filled with brake fluid when you pump the pedal - else you will damage it very fast ! |
01-08-2005, 11:48 PM
I believe Ivan had that problem with his hachi.
So if you want to replace all the brake fluid, how would you get the last bits out of the lines safely then? I want to change my brake fluid intirely when I install my new axle with new brake lines and all. I have no idea whats in there now and I'm thinking of changing to dot 5.1 and I dont like the idea of mixing old with new. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
01-10-2005, 10:38 AM
I can't unscrew oper mount of brake lines. I used WD 40, but with no result.
It is all rusted. Any tips? 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
01-10-2005, 11:47 AM
Ehm...only advice on brakelines I have is to always use special tool that grips the nuts from almost all sides. They have a small opening in front that fits around the brakeline and then you slide it on to the nut...it makes it nearly impossible to damage the nut, which happens really fast with normal tools.
Front big brake kit | DidiDex | 14 | 19,426 |
10-24-2016 09:29 AM Last Post: FanIsHere |
braided brake lines | izanagi | 12 | 12,246 |
11-09-2015 01:24 PM Last Post: The Doctor |
US-spec vacuum hard lines | LordTD | 2 | 5,239 |
04-27-2015 07:18 PM Last Post: Project D |
goodridge SS brake lines fitting doubts | wouter86 | 17 | 18,164 |
04-30-2014 06:33 PM Last Post: wouter86 |
rear window defroster lines | zenki | 3 | 5,592 |
11-15-2013 02:58 PM Last Post: Ivan141 |
User(s) browsing this thread:
