How to reduce throttle axle gap
05-15-2009, 09:29 AM
I had an annoying problem with throttle axle gap for a quite a long time, so I decide to fix it. I took a piece of rubber gasoline hose 10mm inner diameter, 16 outer (reduced to 15 mm) and bout 10mm long and I just pressed it in from the TPS side. To do that, I had to remove TPS and plate for turning TPS. After I stick the hose in, I put the TPS back on and recalibrate it. The inner diameter of hose is 10mm, so the axle can move smoothly as the axle has 9mm diameter. I was trying to find an oil seal instead of rubber hose but it seams that there is no 10/15 available on the market, so I just go for a piece rubber hose.
Now I don’t have a gap any more and the throttle is running smoothly and nicely as it should and with out vibrations.
Fun is not the straight line!
05-15-2009, 09:52 AM
pictures
05-15-2009, 10:28 AM
robokill Wrote:pictures
Sorry, I don't have any. I had a dirty hands so i didn't want to mess up my phone. But it is a very easy job, took me about 30 minutes with tps calibration. Maybe this will help:
  AE86 rear axle weight megabob 11 19,715 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 1,323 10-24-2023 12:20 PM
  Rear axle options Dino86 13 13,715 01-08-2018 10:19 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,931 12-21-2016 09:37 PM
Last Post: bozu
  wider rear axle,track width,suspension questions ditn 6 9,329 10-18-2016 11:50 AM
Last Post: fantapants
