How to reduce throttle axle gap
05-15-2009, 09:29 AM
I had an annoying problem with throttle axle gap for a quite a long time, so I decide to fix it. I took a piece of rubber gasoline hose 10mm inner diameter, 16 outer (reduced to 15 mm) and bout 10mm long and I just pressed it in from the TPS side. To do that, I had to remove TPS and plate for turning TPS. After I stick the hose in, I put the TPS back on and recalibrate it. The inner diameter of hose is 10mm, so the axle can move smoothly as the axle has 9mm diameter. I was trying to find an oil seal instead of rubber hose but it seams that there is no 10/15 available on the market, so I just go for a piece rubber hose.
Now I don’t have a gap any more and the throttle is running smoothly and nicely as it should and with out vibrations. Fun is not the straight line! |
05-15-2009, 09:52 AM
pictures
05-15-2009, 10:28 AM
robokill Wrote:pictures Sorry, I don't have any. I had a dirty hands so i didn't want to mess up my phone. But it is a very easy job, took me about 30 minutes with tps calibration. Maybe this will help: Fun is not the straight line! |
AE86 rear axle weight | megabob | 11 | 19,657 |
Axle width | totta Crolla | 1 | 1,307 |
Rear axle options | Dino86 | 13 | 13,653 |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,924 |
wider rear axle,track width,suspension questions | ditn | 6 | 9,279 |
