How to set ignition timing???
06-24-2008, 09:24 AM
So if the timing is supposed to be set at 5 degrees, I take some chalk and put a mark on the belt at five degrees while the car's off? The start the car and see if the light flashes on the mark? How far should I hold the timing light from the belt? And does this sound right?
Jason
06-24-2008, 10:09 AM
Quote:To set the timing you need to get hold of a timing light and a short
piece of copper wire to jumper (short together) terminals T and E1
in the diagnostic connector. With T and E1 shorted together, the
ignition timing should be set at 10 deg BTDC at idle (800 rpm).
Without T and E1 shorted, the timing will jump to around 26 deg
at idle (10 deg base timing plus advance added by the ECU).
The timing marks are on the bottom timing belt cover, and match to
the notch in the back flange of the crankshaft pulley. If you clean the
cover up and highlight the notch and 10 deg marks with white paint
they will be easier to see.
Some early cars have a round, yellow (I think) diagnostic plug instead
of the square, black diagnostic connector. Two of the pins in the plug
have to be shorted together, but I'm not sure which two Confused
To get your car to idle at 800 rpm it will either have to be warmed
up, or you will have to block off the idle-up bypass port in the throttle
body. Use gaffer tape or a small rubber plug. I think thats about
everything covered Smile
The 10 deg base timing applies to 16V 4AGE with EFI. The timing
marks are down by the crankshaft pulley, so you need to get the
light shining down on the pulley. The mark on the pulley will appear
to be stationary under the strobe, and you see where it lines up
with the scale on the timing cover. Rotate the distributor until the
notch on the pulley is opposite the 10 deg marking.
Cheers... jondee86
06-28-2008, 11:16 PM
Very important to bypass the plug on the firewall with a jumper. This affects it greatly!
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
06-30-2008, 02:31 AM
anyone know where's the vacuum advance hose on a 4ac?
  Ignition switch plug and wires Blaze0010 3 127 11-25-2024 12:29 PM
Last Post: Blaze0010
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,310 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  4agze timing leon205gti 11 13,486 04-07-2017 03:10 AM
Last Post: jondee86
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,266 11-05-2016 01:34 AM
  extracted freedom ecu 16v ignition map ditn 7 8,750 08-22-2016 10:01 AM
Last Post: ditn
