How to tell the difference between ECU´s
08-31-2011, 08:39 AM
So, how to tell the difference between an ECU coming from a car with AFM or MAP sensor?
Or are both the same?
Cheers Marco
AE86 Full Hybrid - Burns rubber and gasoline
08-31-2011, 10:33 AM
by the partnumber on the label - there is no physical difference
08-31-2011, 10:40 PM
Gr8, thanks.
09-01-2011, 09:52 AM
By Toyodiy:
Zenki:
MAP ECU:
89661‑12060
MAP ECU, FRG SPEC:
89661‑12090 (04/1985 - 04/1985)
89661‑12130 (05/1985 - 03/1987)
MAF ECU:
89661‑12090
MAF ECU, FRG SPEC:
89661‑12100
Kouki:
MAP and MAF ECU
89661‑12091
MAP and MAF ECU FRG spec
89661‑12160
Not sure how same ECU can work both MAP and AMF, but that's what Toyodiy says Smile
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 7,319 07-31-2019 11:28 AM
  Axel anyway to tell the difference? MIGGZFSU 7 8,195 10-24-2017 08:48 PM
Last Post: MIGGZFSU
  Why Zenki and Kouki colour difference MIGGZFSU 10 20,001 04-23-2017 09:16 AM
Last Post: MIGGZFSU
  Windshield difference d3nso 3 6,625 03-26-2016 02:21 AM
Last Post: fax0815
  brake booster difference zenki(2 bolt)/kouki 4 bolt v ditn 1 4,537 03-22-2016 09:43 PM
Last Post: ditn
