How to tell the difference between ECU´s
08-31-2011, 08:39 AM
So, how to tell the difference between an ECU coming from a car with AFM or MAP sensor?
Or are both the same? Cheers Marco AE86 Full Hybrid - Burns rubber and gasoline |
08-31-2011, 10:33 AM
by the partnumber on the label - there is no physical difference
AE86 ex-daily |
08-31-2011, 10:40 PM
Gr8, thanks.
09-01-2011, 09:52 AM
By Toyodiy:
Zenki: MAP ECU: 89661‑12060 MAP ECU, FRG SPEC: 89661‑12090 (04/1985 - 04/1985) 89661‑12130 (05/1985 - 03/1987) MAF ECU: 89661‑12090 MAF ECU, FRG SPEC: 89661‑12100 Kouki: MAP and MAF ECU 89661‑12091 MAP and MAF ECU FRG spec 89661‑12160 Not sure how same ECU can work both MAP and AMF, but that's what Toyodiy says |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,797 |
Axel anyway to tell the difference? | MIGGZFSU | 7 | 7,830 |
10-24-2017 08:48 PM Last Post: MIGGZFSU |
Why Zenki and Kouki colour difference | MIGGZFSU | 10 | 19,112 |
04-23-2017 09:16 AM Last Post: MIGGZFSU |
Windshield difference | d3nso | 3 | 6,401 |
03-26-2016 02:21 AM Last Post: fax0815 |
brake booster difference zenki(2 bolt)/kouki 4 bolt v | ditn | 1 | 4,336 |
03-22-2016 09:43 PM Last Post: ditn |
