How to test coil with igniter
03-21-2018, 12:02 AM
Hey guys,
I have some problems getting my engine running. Somehow i don't get a spark. Starting the engine with or without the 'coil with igniter' gives me same result, so i bet it should have something to do with the coil w igniter. What I did to test the coil: 1. Testing primary resistance between coil + and - terminals = 1 Ohm 2. Testing secondary resistance between coil tower and + = 12.6k Ohm So my guess is that the coil is fine. The igniter gets juice: 1. Red=12v, Yellow=5v and one giving a changing 0-2.5v when cranking. I got new ignition cables. Could it be my distributor? 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
03-21-2018, 09:54 PM
Perhaps you got some connectors mixed up?
Happened to me once with one of the sensor connectors long ago.. accidentally swapped it and the car just would not run. Testing spark should be easy by the way... pull a plug wire and use it with a spare sparkplug that you ground on the chassis.. See spark, then you know that's ok. Test for fuel pressure at the banjo to see if fuel is arriving. If those 2 things are present then it's either sequence or injectors going wrong.. FABRICA MI DIEM, PVNC! |
03-22-2018, 10:01 AM
To test the coil (alone) you always could do it the simple way by hot-wiring it.
Wire the + of the coil directly to the + on the battery (disconnect the rest) and just touch the - of the coil with a loose wire connected on the other end to the - of the battery. The coil need only a few milliseconds to fire (dwell) so don't connect it too long on the - or you will fry it. Also don't forget to connect a spark plug on the output or it will arc at your hand. By the way, did you check if your distributor was aligned properly ? if the rotor is not aligned with one of the post on the cap when the ECU try to fire the coil you obviously don't get any sparks. Finally, ESA (MAP) or VAST (AFM) ? |
Smallport coil | totta Crolla | 2 | 2,352 |
08-12-2022 11:03 AM Last Post: totta Crolla |
Comp. Test - 20v Blacktop | hachirokkos | 2 | 5,363 |
01-10-2016 02:30 AM Last Post: hachirokkos |
4age igniter question! | Ghetto | 1 | 5,425 |
01-09-2015 11:30 PM Last Post: Uzelac |
Emissions test failed due to high CO2 levels in IDLE | heshan | 1 | 6,332 |
09-04-2012 08:00 PM Last Post: banpei |
digital cluster on 4agze coil packs?? | KameleonK | 6 | 10,334 |
03-21-2012 12:54 PM Last Post: Ivan141 |
