Hydraulic handbrake with stock rear brakes
05-31-2014, 11:20 AM (This post was last modified: 05-31-2014 11:27 AM by Dino86.)
Hi,
I installed a hydraulic handbrake (0.625").
I'm using stock rear brakes.
I know in general, the OE rear brakes s*ck.
But even with my hydraulic handbrake it's hard to get the rear wheels locked.
It works on lower friction asphalt. On high friction I can just lock the inner (unloaded) wheel while cornering.
Bleeding is OK, since brake pedal feeling is same as before.
Is it normal that even with hydro handbrake the rear is difficult to lock? In other words, are the brakes even worse than I thought? Smile
05-31-2014, 01:35 PM (This post was last modified: 05-31-2014 01:36 PM by fax0815.)
Hi, can´t complain about the AE86 rear brakes? You´ve done everything right, 0.625 cylinder is perfect for most cars.
I´ve had the same setup for years, and they have always worked excelent, how´s the condition of your discs/ pads, if they are old rusty or really worn that affects the performance of the handbrake.
But I´ve also rebuild the calipers a while before I fitted my handbrake, the self adjuster was seized on on side, so they were adjusted uneven and didnt work properly, that might be worth a try?
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
05-31-2014, 06:53 PM
(05-31-2014 01:35 PM)fax0815 Wrote:  Hi, can´t complain about the AE86 rear brakes? You´ve done everything right, 0.625 cylinder is perfect for most cars.
Brake disc and pads are in good condition and well run in.
Rebuilding calipers might be a good option as a next trial. Just need to find a rebuild kit. I skipped the rebuild before since I could not get hold of a kit. Need to search harder... Any good address (online)?
05-31-2014, 07:35 PM
had the same problem
could not find a rebuild kit in belgium
but later i found this
http://www.rexbo.eu/trw/repair-kit-brake...07&at=3183
hope it will help you
grtz
06-01-2014, 04:44 PM
Allways get the kits from Toyota? its like 50€ for a full kit, thb if its the adjuster you wont even need the rebuild kit, jsut take everything apart, make sure it moves freely and put it back together?
06-14-2014, 02:51 AM
Is the pin on the brake pad backing plate lined up with the caliper piston cut outs? If not your not grabbing evenly and it will barely work.
FYI: do this, if you haven't already. http://www.aeu86.org/forum/printthread.php?tid=11078
Andrew
06-14-2014, 10:13 AM
How have you made the connection to the master cylinder ?
Mine has a tab welded onto the stock handbrake lever with a short rod going to the master cylinder and there is only just enough leverage to lock the wheels and it is not consistent.
In my case the standard cable handbrake is better.
06-15-2014, 03:00 PM
Thanks for All replies.
@boedtsie and fax: Thanks for the link I will have a look. I was told toyota ran out of stock.
@assassin: yes it's lined up. I also followed the explanation from your link already but no change.
@totta: mine is a separate handbrake. No DIY on the original lever. I extended the lever to the Max lengte already.
07-05-2014, 07:32 PM
Then what brake pads? Those can make a huge difference.
Andrew
07-06-2014, 04:53 PM (This post was last modified: 07-06-2014 04:53 PM by Dino86.)
(07-05-2014 07:32 PM)assassin10000 Wrote:  Then what brake pads? Those can make a huge difference.
Andrew
I currently have the stock rear pads. Discs are new since last year (+-4-5000km)
Can you advise on some high friction pads for the rear?
Thanks
  Handbrake adjustment discs? DMC 8 1,798 03-10-2024 08:08 PM
Last Post: DMC
  Rear brakes totta Crolla 0 924 02-03-2023 12:54 PM
Last Post: totta Crolla
  Digital speedometer on stock dashboard FanIsHere 0 1,388 11-09-2022 01:36 PM
Last Post: FanIsHere
  Switching diffs for disc brakes? trippin 6 2,649 07-08-2022 03:35 AM
Last Post: trippin
  82mm Stock compression Pistons apardal 4 2,798 11-24-2021 04:26 PM
Last Post: apardal
