I blew my diff
08-17-2005, 10:24 AM
I blew my diff
Well it happened today, I blew my diff. Well I wont get into details on how I blew it.
I have found another one for a mere $150 NZD which is not to bad. I went to take my old diff hat out tonight and got one axel out but the one on the left wont because on of the nuts holding it into the brake/diff casing is rounded off. Any ideas on how to get this nut or bolt out. I cant fit a angle grinder in there and cant force a spanner or socket on there. I might bring a cold chisel home from work and try smashing the bolt off. But any ideas would be great
Heres a photo:
[Image: AEU86 AE86 - I blew my diff]
Sorry about the bad image, its from my cell phone.
08-17-2005, 11:13 AM
I blew my diff
You can weld an old wrench on it, or a bigger bolt...If I remember correctly you can physically take out the bolts from the rear of the flange, so finding a way to cut it off might not be a very bad idea.
08-17-2005, 12:07 PM
I blew my diff
Ah, nice drumbrakesSmile
Another option would be to drill a hole into the center of the bolt and use some left threaded bolt or similar to get it out. Left threaded bolt will fasten itself into your old bolt by screwing it in counter clockwise and once in fully you can now screw out your oldbolt in the normal manner..
I have a nice set with left threaded bits especially for this, costs me a couple of bucks but well worth it (unless if you only bring your only clockwise turning drill along like I did not that long agoSmile )
08-17-2005, 12:37 PM
I blew my diff
Mux, the idea with the left treaded bolt wont work in this case. Its the nut thats rounded, therefor he needs to remove that first. As i remember, the nut is a 14`, so i would try smashing a 13` on it. If that doesnt work, use one of those plyers a plumber uses. Or take the chissel, and "cut" the nut in two Tongue
08-17-2005, 12:54 PM
I blew my diff
weld a pice of pipe so u can use that for leverage (like a wrench), and heat the screw with some sort of torch then try unbolting it. hamering a couple of times on tho screw head cann help to releave the thension of bolted connection and then screw can be unbolt easyer also.
08-17-2005, 01:03 PM
I blew my diff
Ah crap, sorry I missed that bit, thought it was a boltSmile
Yeah then either cutting it off or welding something on it seems to be the only way...
08-18-2005, 12:56 AM
I blew my diff
DRUM BRAKES ROCK Evil lol
Yeah I dont have a welder so I was thinking that I will use my high powered drill and just drill the bold out, if you know what I mean. Drill the center on the bolt and keep on going larger in drill size. Once the nut has been drilled alittle and the bolt is weak I will get a cold chissel and smack the bolt and nut off.
Sounds easy
08-18-2005, 08:24 AM
I blew my diff
$150 for an AE85 diff Huh ?? Is it the whole diff or just diff head?
08-18-2005, 08:58 AM
I blew my diff
Thats just the diff head...why is that expensive...I cant find any other ones in NZ on such short notice.
BTW welcome to AEU86.org...nice to have another Kiwi on board!
08-18-2005, 09:05 AM
I blew my diff
Ok so here some pictures I took about 15mins ago...enjoy.
[Image: AEU86 AE86 - I blew my diff][/list]
  What Diff Oil For a Clutch plate diff? jamieae86 10 13,848 12-16-2011 11:14 AM
Last Post: bakonick
  weight diff head diff center fax0815 5 6,533 12-21-2010 03:03 PM
Last Post: fax0815
  Celica F-diff with Hilux/ Pickup Torsen diff Roye 7 11,247 04-29-2008 09:13 PM
Last Post: Roye
