I would like to puchase AE86- help
01-07-2013, 12:59 AM
Hello
I would like to buy Toyota corolla AE86 i choose levin kouki but I have some questions about this car.
1.) I would like to buy car with auto-locking (LSD) differential how I recognize if car have it or no. ( Only some types= which, only some production years which...etc)
2.) Which emission norm AE86 have= registration authorities
3.) Are there any traps or weaknesess which used or badly mainteined AE86 can have...
4.) which version is best ? ( some GT...etc) - only kouki version
Thanks a lot for ansvers- my english isnt very good so some technical term please write simply
THANKS Respect! Respect! Respect!
01-07-2013, 01:17 AM
well, GT EU versions of that model all have LSD as far as I can remember?
But to check there is a model type on the chassis plate of the rear axle believe its
283 or 285 for an LSD axle (i am doing this by heart so double check the tech section)
But you never know if it has been swapped out. To make your life more eazy. Contact some locals through the forum.
An AE86 are near impossible to find in mint condition so my points is always to do a full service on the engine /oils running gear and then work your way up from there.
01-07-2013, 01:25 PM
I also think alll european models have an LSD
only the sr? models in usa dont have LSD
check for rust on the know points,
pockets in the rear everything underneath
inside the wheelbase
check if the lsd is working
check if the gearbox shifts correct
check if the engine pulls good
check the bearings for play
kouki ae86 have the the thicker half shafts in the back
i think the coupe version is lighter and bit stiffer?
01-07-2013, 06:07 PM
To check for lsd, rev it and let clutch go. If there's 2 black stripes on the ground it has lsd. But i don't know if the owner would let you. Tongue
Like robokill said, good maintained ones are difficult to find. They exist but they go crazy money these days.
Also take out the back seat and look for rust under there. Most of them have rot where the seatbelts are attached and on the inside wheelwell.
ハチロク
[Image: AEU86 AE86 - I would like to puchase AE86- help]
01-07-2013, 06:36 PM
I might have exactly what you are interested in
01-07-2013, 10:17 PM
robokill Wrote:well, GT EU versions of that model all have LSD as far as I can remember?
Except for DJexors hachi which had an open diff from factory for some weird reason. Wink
01-08-2013, 06:20 PM
RUSTY88 Wrote:Hello
1.) All EU spec AE86´s should have an LSD, but to be sure jack the rear axle up, turn one wheel by hand, if the other wheel turns in the same direction=LSD if it turns the other way= open
2.)might be better to ask someone from your country, try them?
http://www.aeu86.org/viewtopic/86ers-fro...ue/t/11372
3.) rust and everything else you whould expect from a almost 30year old car...
4.) very difficult to stay ahead of all the different models, also depends where your car was sold, in Germany the AE86 was sold as 2dr only, named Corolla GT, but as far as I´m aware they´ve never had a Kouki model.... Swiss Ae86´s were 3dr and had an uprated LSD, iirc and so on...
And it get a lot more confusing with japanese modells...
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
01-08-2013, 08:44 PM
good point but could have been a swapped axle? I couldn't get that thing sideways :-)
01-08-2013, 09:40 PM
robokill Wrote:good point but could have been a swapped axle? I couldn't get that thing sideways :-)
I remember we checked the vinplate and it stated it featured an open diff.
  Ae86 eats fuel pumps like skittles livelaughlevin 4 1,519 05-15-2024 10:41 PM
Last Post: livelaughlevin
  AE86 Dedicated portal - Would you be interested? Alex 9 10,644 09-11-2014 09:00 PM
  New Rota Designs. What would you like? nmwisima 10 15,547 11-11-2013 03:03 PM
  Need your help,looking for a rallcar thats looks like this ditn 17 21,794 04-11-2013 07:13 PM
Last Post: ditn
  This would be fun totta Crolla 1 4,728 07-21-2011 10:02 PM
Last Post: totta Crolla
User(s) browsing this thread:
