IAC valve
05-28-2010, 09:45 PM
IAC valve
i have i high idle on my engine and I'm talking about 1800-2000 rpm, and I'm sure that the Idle Air Control valve doesn't work, is there any way that this can be blocked so the engine can come back to a normal idle ...? and if so how can i fix this problem ?
'85 Corolla Sprinter Trueno GT-APEX
05-28-2010, 10:31 PM
IAC valve
can't you try to clean it ?
Gtsi-R
"Trust me, I was an engineer"
05-28-2010, 10:49 PM
IAC valve
How do i clean it. I just have to take it out and clean it but is there a special fluid to clean this ..?
05-28-2010, 11:47 PM
IAC valve
CoolinAE86 Wrote:i have i high idle on my engine and I'm talking about 1800-2000 rpm, and I'm sure that the Idle Air Control valve doesn't work, is there any way that this can be blocked so the engine can come back to a normal idle ...? and if so how can i fix this problem ?
Go inside the throttle body and find the idle air port. Its just in front of
the throttle butterfly at about 5 o'clock. Block the hole temporarily with
a rubber plug or even your finger (for testing). If the idle drops by
1000 rpm, then your thermostatic idle-up valve is stuck wide open (if
the idle only drops by 100 rpm, the problem is elsewhere).
You can block it off permanently and put up with poor cold starting and a
rising idle, or fix/replace the valve.
Cheers... jondee86
05-30-2010, 08:22 PM
IAC valve
Cheers... jondee86
Thanks man the valve was stucked so i will try to block it up permanently thanks man
  4AGE Valve Buckets Scored Steller Engineering 2 1,071 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,655 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,484 05-25-2022 10:24 PM
  Valve clearance leon205gti 7 8,989 11-25-2016 03:24 AM
  16v oversize valve seats harkes 9 12,882 09-20-2016 05:04 PM
