ITB convert need standalone ECU
04-06-2016, 11:57 PM
Hi all,
Just for my knowledge.
Why when doing an ITB conversion we need another ECU ?
The stock ECU would not works.
It there a problem with the ignition, the MAF or MAP, TPS , etc.....
Thanks for your explanations.
04-07-2016, 12:35 AM
This is a very loaded question. I'll try to keep the answer short.
The stock ECU has only very marginal capabilities to adjust for changes. Fitting ITBs changes the MAP signal drastically. Therefore keeping everything else stock you will not just loose some power through the range but it will also affect driveability an fuel consumption.
Now add a set of cams and the ECU is definitely overwhelmed.
This is all considering a MAP controlled engine. If the stock engine was running an AFM the ECU can't control a MAP signal at all.
Long story short going for ITBs for performance reasons is in most cases only necessary above 160hp @ engine and that's aiming very low. More realistic is 180+ and even in those cases a bigger or altered throttle body would do the trick just fine. Most people change to ITBs for the looks and sound alone.
04-07-2016, 11:24 PM
(04-07-2016 12:35 AM)Bean Bandit Wrote:  This is a very loaded question. I'll try to keep the answer short.
Thanks for the answer.
Perfect
  Can you convert your 86 back too the original state? gh0st 7 2,828 04-25-2022 04:25 PM
Last Post: gh0st
  TRD ECU need help ps13michi 5 3,926 02-18-2022 10:42 AM
Last Post: ps13michi
  20V VVT on standalone ECU fax0815 5 10,088 08-09-2013 09:27 AM
Last Post: rene
  genuine AE86 seats -> convert to rails ? Uzelac 8 8,868 10-14-2011 04:09 PM
Last Post: Uzelac
  Which standalone ECU for a Blacktop??? Aram 9 13,121 08-11-2010 07:47 PM
