In London and brought my car from OZ
09-04-2016, 12:07 PM
Ok, it's out ........
Luckily the bias installer was generous with the cable length so I didn't have to pull it out. So, should I get a sticker to put over it? Or a MPH fascia? Who does that over here? Just looking at the handbrake. Is a fly off type going to be a problem? Will they be happy with internal braided lines? |
09-04-2016, 03:13 PM
the original fascias are two pieces, though I doubt you'll find someone selling you just the mph bit. Your best chance is to find someone in UK or Ireland to sell you one of their clusters and put it in.
Not entirely sure on UK law but I though the fly off type is legal as long as you can secure it in the pulled status. Braided line should be fine I guess. Someone from the UK will be better to answer that. You'll need at least a temporary fog light at the back to pass the MOT. AE86 ex-daily |
09-04-2016, 05:30 PM
Hi, welcome to the U.K !
The hand brake will probably need the cables installed to pass the MOT test. No problem with the braided brake lines, inside or outside. What do you use the car for ? An analogue brain in a digital World |
09-04-2016, 10:49 PM
Well, I actually haven't used the car for anything yet. Bought it last year as a very very safe car for my missus to drive to maybe get her interested in coming along to some events but moved to London before I was able to get it finished and didn't want to part with it. A bit of a 1 in a Million shell that I couldn't pass up. There are whispers of 'gee, that could buy us a new bathroom and kitchen if you sold it' but I drove it home from Tilbury and the smile on my face had other thoughts ............ The sooner I get it on the road, the more Brands laps I can do before it's put on the chopping block.
09-05-2016, 12:37 PM
Welcome!
![]() As has been mentioned, I believe the handbrake has to work independently of hydraulic action to pass an MOT. Being an emergency brake, it has to be usable in case of line rupture/fluid loss. If it's plumbed in to standard rear calipers, see if you can find yourself an OEM handbrake and cable set and offset your hydraulic to keep its functionality. This might sort out your dash "issue" but I just had a phone holder with GPS speedometer app, worked very well and you could set up speed warnings etc if you had a heavy right foot. |
09-05-2016, 07:35 PM
'IF' ...... haha
Lead Boots!! Hopefully a locking hydraulic handbrake will be ok as it will be a complete ball ache otherwise. Took a couple of snaps of the calipers and I'm not sure what they are. Look kinda like Subaru?? Doesn't look like any other handbrake mechanism. They probably had a drum brake handbrake??? |
09-05-2016, 09:18 PM
Probably Nissan Z32 rear brakes, not bad
09-06-2016, 12:25 PM
Looks like it, Nissan Z32 Sumitomo calipers.
![]() Depends how friendly your MOT man is I think. Some still don't allow locking hydraulics (fluid failure still possible), in that case, I think you might have to look at a Spot caliper from Hispec or Wilwood etc as the Z33 used Drum in Disk handbrake. Looks like yours has had a pretty penny spent on it looking at the rear end setup
09-06-2016, 08:11 PM
If hydraulic failure is an issue, then maybe it will be ok as the front and rear may be separate?
Good brake sleuthing there d3nso! |
09-07-2016, 02:21 AM
Looking at it, it might fall under the "limited use/specialist" MOT regs.
I'm not sure what it entails but it's to essentially relax the regs for cars that are quite clearly not "road cars" per-se but feature basic lights and safety features to enable it to be used on the roads. Best bet, is to find a local tester and ask him about it, buy him a case of beer - might struggle to find VB here though
| New Member from London | tflpunk | 10 | 13,358 |
07-17-2011 11:35 PM Last Post: Lauren |
| Hello From London Town! :D | ae_86 | 5 | 7,197 |
03-04-2010 09:20 PM Last Post: oldskull |
| Hello from London!! | Kryptize | 7 | 7,553 |
02-26-2010 10:26 PM Last Post: Kryptize |
| a big hello from south london | geoffersmaher | 22 | 20,373 |
01-11-2010 01:46 AM Last Post: Lajoosh |
| Hello to all from London - Car soon for sale! | Coggers | 1 | 3,753 |
04-09-2008 08:03 PM Last Post: Coggers |
![AEU86 AE86 - In London and brought my car from OZ [Image: AEU86 AE86 - In London and brought my car from OZ]](http://www.thumper300zx.com/z32/brakes_rotors/rear_caliper.jpg)
