Installing seatbelts
09-19-2004, 09:15 AM
Hey Everyone,
OKay, so as most of you know i have 4 points in my car. Now I want to be able to use this car for daily use and the ocasional track event so 4 points are not a must for me, but the use of the rear seat is.
So I have desided to go back to the stock 3 points, which the previous owner has misplaced, so I got a set from Jesse (thanks!) he had lying around. Problem with this set is that they've roled all the way up and seem to be stuck.
Anybody got any experience with making these seatbelt unstuck without comprimising they're use in the unlikely event of an accident?
09-19-2004, 03:58 PM
Yeah....
You need to bolt the seat belt mechanism onto the mounts with the 14 and 10mm bolts. When it is bolted in place, the tension on the mechanism frame will allow the reel to unwind.
09-19-2004, 05:12 PM
Will,
It is indeed the holding it in the right way that solved it. The problem though was that the seatbelt was rolled up so far, I needed both hands to get it to wind a tad bit further for it to release. After I figured that out it rolled like crazySmile
So now I finally have normal seatbelts and normal seats back in my car!!Smile
Strange thing though, brown seatbelts in a blue interiour hachiSmile
09-19-2004, 07:14 PM
mux213 Wrote:So now I finally have normal seatbelts and normal seats back in my car!!Smile
Yay! That's a big improvement for getting in and out of the car agian. Wink
[Image: AEU86 AE86 - Installing seatbelts]
09-19-2004, 07:27 PM
owh man, especially for someone my size!Smile
10-01-2005, 10:45 AM
A small kick from your friendly admin. Wink
Yesterday I got a call from Robokill while he was installing his seatbelts. He had exactly the same problem as I did when I installed the seatbelts: don't mix up your seatbelts. They fit on both sides but don't release the belt when mixed up. The only way to distinguish them is by looking at the plastic cover: it doesn't fit that well if you mix them up, but if you have stipped your car like Robokill you can't tell the difference. Wink
If you remove your belts from the car: don't let them roll up, keep them as long as you can. Also mark them left and right to prevent confusion. Smile
Edit: I've used Apardal's rebuild to show the seatbelts
  Start wont turn over after installing radio MC_JP 6 11,659 09-22-2014 11:13 PM
Last Post: izanagi
  Problems installing yellow koni's in my TE71 liftback teun 12 18,356 11-09-2013 03:01 PM
Last Post: teun
  probs installing Battle Version #2 kit, please help cj 10 17,053 11-28-2012 03:25 PM
  Hatch seatbelts - question cannabolic 1 4,251 07-28-2011 09:43 PM
Last Post: cannabolic
  difference when installing OEM or Cusco LSD aussiefan 3 5,328 09-27-2010 02:39 AM
Last Post: assassin10000
