Interesting engine
11-04-2005, 11:33 PM
Interesting engine
what does everyone think of this engine
what will be needed to run it right or will it just slot straight into an 86 withy no problems Toyota 4AGE 1600cc 16 valve OMEX managed engine on Throttle Bodies . . . Originally built by Raw Engineering in 2002 to TracPac Two (170 BHP) spec. at a cost of over £4000 - ran approximately 4000 miles as such. Now up-rated by Paul Jackson of BPJ Engines to Irish Tarmac Rally Championship high torque spec. (at a total cost of £4100 and with zero miles since) via: Fully machined rally spec. cylinder head with re-profiled valve seats and ports - valve size increased to suit short duration high-lift cams - new 1089 profile camshafts (245o @ 50th lift ), 32mm inlet valves, new valve springs and steel top caps and 28mm steel cam followers. Cometec head gasket, 45 mm throttle bodies, OMEX 500 fully mappable 3D engine computer, uprated fuel regulator, injectors and pump etc. Also has Tollbar Racing unique and safety minded anti-cavitation re-circulating water pump system. Absolutely fresh (can be seen/heard running in car) and would suit race, rally or road for Corolla, MR2, various kit cars Escort, Sunbeam, etc. |
11-05-2005, 02:55 AM
Interesting engine
Peugeot 206 1.6 XT - 09/2003 Toyota Corolla GT Coupé - 09/1984 Yonzie - 09/1980 |
11-05-2005, 06:57 AM
Interesting engine
I can't see the picture...hmmmm.
I once read that you shouldnt believe everything you read. |
11-05-2005, 12:07 PM
Interesting engine
cause there isnt a picture
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,820 |
Interesting 20v cam cover mod | banpei | 3 | 9,362 |
05-31-2012 02:44 PM Last Post: Kid Karola |
interesting article | totta Crolla | 3 | 4,514 |
03-19-2009 10:52 PM Last Post: totta Crolla |
Need engine,any engine | Apolan | 25 | 20,854 |
10-29-2006 06:55 PM Last Post: ZaX |
interesting difference - AFM/MAP version test | Ryo | 3 | 4,567 |
04-18-2006 05:20 PM Last Post: Ryo |
