Is the electrical fan conversion any good?
05-03-2009, 07:40 PM
engine turning faster would mean more rear wheel HP right?
Cheated on my いたずらな女の子 and now I can't get enough of her..
05-03-2009, 08:21 PM
i did that to my AE...
had problems with mecanical one, and broke 2 water pumps Crying
i took radiator from T160 Celica, radiator have electric fan attached to it...
made 2 holders down to hold radiator and uper holders were from old one...
only hoses were the problem couse i was hard to find what i nedded...
celica rad have plug from the other side so hose is longer... i needed exact 1m...
and the good thing, rad is much bigger than stock one... so suppose thats a good thing...
and electrics is easy...
just put some new wires from battery and i made a on/off switch on dashboard Tongue
and cant say that i feel the improvement at responce...
so its minor responce
05-03-2009, 11:05 PM
I use a KE70 one and it works wonders
[Image: AEU86 AE86 - Is the electrical fan conversion any good?]
05-04-2009, 12:51 AM
Pfff.. with all these expenses in rebuilding my hachi, now i must look out for new radiator with electric FAN Smile.
Please stop mentioning all these upgrades for few months Big Grin
05-04-2009, 04:43 PM
tell me about it.. I'm spending all my wedding money on my car..
05-04-2009, 07:05 PM
Hachi Wrote:i did that to my AE...
Pa decko, javi da je kupejka u redu, nemoj da nagadjamo sta se sa njom desava nakon onog nesretnog slucaja na Adi huji. Lepo je cuti da je sredjena i da ide Smile
05-05-2009, 01:05 PM
haha Cool
radi auto ali ne vozi se puno, (nemam tablice)
udarila kriza i problemi pa se nema za reg Crying
05-31-2009, 07:33 PM
hey guys I bought a radiator for the conversion. Not sure whether this will workout but going to try out.
Its a late model Corolla rad with a single electrical fan but can fit another one which I'm planning to.
Got it for 65USD.
It's longer than the stock radiator so I guess one side of the radiator has to be hinged to a fabricated mount. and the top inlet is far towards the right so I'm not sure hosing can do the job.
what do you guy think? Can a set of silicon hosing could do the trick to the change of water inlet???
Sorry for the low quality images..
Thanks in advance, Heshan.
05-31-2009, 11:50 PM
There will be a lot of work involed in mounting that radiator, to mount it central in the engine bay you will most likely have to remove you battery holder, an easier option is to mount an aftermarket fan onto your factory radiator, they are usually more powerfull and are a compact design compared to factory fans.
For example:
Going against what I have said above that is what I did in my car, I installed a radiator from a Honda Integra which is wider but it was a twin core and I mounted an aftermarket fan to that. To mount the radiator it required custom made top and bottom mounts.
Corolla Levin SR 1984 AE-85 (Project car)
Corolla Runx Z 2002 (Runabout)
06-08-2009, 09:08 PM
we did a dualfan conversion like this
Fan on Ebay
on a S14 and we went from boiling coolant while racing grip to a stable temperature of 83-86 degrees celcius.
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
  20v Blacktop conversion.... Mylesmck 0 439 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 2,092 02-08-2024 10:30 AM
Last Post: r.ave
  Squeaky seats - any tips? decryphe 2 998 10-18-2023 10:13 PM
Last Post: Power_uP
  ClutchMaxPRO Clutches - Good or Bad? RolanTHUNDER 0 1,047 12-01-2022 09:55 AM
Last Post: RolanTHUNDER
  AFM to Map Conversion ps13michi 3 3,109 01-06-2022 10:34 AM
Last Post: ps13michi
