Issues with the transmission or the clutch?
01-27-2008, 07:18 PM
The car doesn’t shift when the engine is on, just when it is off, I Bleed the clutch system and cleaned the master cylinder, but still doesn’t shift.
When I try to put reverse the transmission grinds horrible, any Idea.
I drove the car back to home by putting it on first gear and then starting it.
Please Help
Sergio
01-27-2008, 07:57 PM
Have a look underneath the car and have a friend press the clutch pedal.. look if you see any movement at the clutch arm on the bellhousing.
If you dont, then it's a hydraulic problem, otherwise maybe a wrong pressure/ clutch plate or release bearing..
01-27-2008, 08:10 PM
Thanks Ivan, the clutch indeed is working if I press the pedal it feels strong but when the car is on it doesn’t shift.
01-29-2008, 11:11 PM
If the car has not been used for some time the clutch plate may be seized to its shaft or the flywheel. It is possible to free it off without removing the transmission.
So has the car been stood for some time, 3+ months ?
02-04-2008, 04:42 AM
Sgonzalez Wrote:Thanks Ivan, the clutch indeed is working if I press the pedal it feels strong but when the car is on it doesn’t shift.
No working clutch
[Image: AEU86 AE86 - Issues with the transmissio...he clutch?]
02-04-2008, 07:44 AM
Looks like an abused clutch! Blush
What did you do with it?
02-04-2008, 08:33 AM
Man !!!! You sure got your money's worth out of that plate Huh
It should have been junked when the spline hub tore out, instead of
welding it up. But they all stop working sooner or later, so nothing a
new clutch plate won't fix Smile
Cheers... jondee86
02-04-2008, 07:58 PM
jondee86 Wrote:Man !!!! You sure got your money's worth out of that plate Huh
Cheers... jondee86
Is the flywheel of the 20 valve the same of the 4age of the GTS?
I whant to buy an ACT kit but don't know if the flywheel the car has is the one of the gts or 20 valve one, any measures that can help
02-04-2008, 08:03 PM
no its not the same. diameter is different. 200mm for the bluetop/redtop motors, 212mm for the 20v and 224 fotr the GZE.
02-05-2008, 09:04 AM
As above. Bigport 16 valve motors have a 200 mm (8") clutch.
Smallport 16 valve and 20 valve motors have a 212 mm (8-1/2")
clutch. You can check it by measuring the outside diameter of the
wear face on the flywheel, or the outside diameter of the clutch
plate or pressure plate. They should all be the same.
Getting a full clutch and pressure plate kit would be good idea Smile
And don't forget you need to get a GTS throwout bearing.
Cheers... jondee86
  Running issues sam3007 6 3,027 06-26-2022 01:34 PM
Last Post: Dave W
  Gearbox mount and transmission mount gh0st 9 3,744 05-08-2022 03:28 PM
Last Post: totta Crolla
  Over heating issues MIGGZFSU 12 12,116 05-11-2017 05:09 PM
Last Post: MIGGZFSU
  Shortshifter TRD - Issues pack 13 13,041 09-19-2016 10:57 PM
Last Post: jondee86
  20v Starting Issues mad.matt 10 12,028 09-24-2014 12:44 PM
Last Post: pack
