10-25-2014, 10:58 PM
Post: #431
Door nr 2 is done.
Welding: ![]() ![]() ![]() Much grinding: ![]() Zink sprayed. ![]() ![]() Some temporary paint... proper finish will be done after blasting.. there is just paint, no filler. ![]() ![]() ![]() Check for straightness, the front end is a bit out of line, but it's nothing drastic. ![]() I finished stripping the rest of the parts off the doors so they are completely ready for blasting afterwards. Noticed a couple of things I will need. If anyone has any of these parts or knows if they can be bought new please let me know. -Left front corner window trim (the bit under the mirror): spotweld holding a bit of thread came loose. Dont know if I can fix it without ruining the plastic. Industrial glue might be the answer. -Left inner window guide rail is missing.. this should be bolted inside the rear (doorhandle) side of the door. If I cant find one I'll have to make one. -1 of my door hinges need to be fixed up or replaced. Dont know if bottom or top hinge. -Bottom window trim on both sides will need to be replaced or fitted with a new bottom window seal.. Old dried up ones tend to hold crud in them and cause scrapes on the windows. FABRICA MI DIEM, PVNC! |
10-26-2014, 10:07 PM
Post: #432
Nice work!
Did you have enough room in front of the Celica or did Berend move his Benz out of the bodgeshed? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
10-26-2014, 11:57 PM
Post: #433
That's a charade back there?! :O
BEAST! |
10-27-2014, 10:41 AM
Post: #434
@Banpei: The benz was out of the way so I had plenty of room.. It did dropin for it's 2-weekly repair though
![]() @Pack: Yes, that would be Thomas' (the Doctor) Daihatsu charade. I think it is presently very close to going to a wrecking yard due to it's automatic transmission being broken, and Doc having enough work on his hands getting the KE20 going again. The charade is not a turbo though.. he just swapped the nicer bumpers and gauge cluster on it. FABRICA MI DIEM, PVNC! |
10-27-2014, 02:09 PM
Post: #435
The Charade is going to a daihatsu garage, to be reborn, or to be broken for parts to keep others alive, depending on what the owner thinks of it
![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
10-27-2014, 02:15 PM
Post: #436
That's a much better solution
![]() FABRICA MI DIEM, PVNC! |
10-31-2014, 02:02 PM
(This post was last modified: 10-31-2014 02:20 PM by Ivan141.)
Post: #437
Reminder to self:
Found some partnumbers on http://toyotamarket.ru/ (online EPC with pics). Prices as specced by Amayama.com ex.shipping. Kouki lower window guiderail (LH): 67408 FRAME SUB-ASSY, FRONT DOOR, REAR LOWER LH 6740412041 01 1984/05-1987/04 AE8# PLANT.M21-M22 USD 21.90 6740412071 01 1984/05-1987/04 AE8# PLANT.A51-A54 USD 19.97 Weatherstrips for door windows: Outer: LH: 6785312010 01 1983/05-1987/04 AE8# USD 14.75 RH: 6785312010 01 1983/05-1987/04 AE8# USD 14.75 Inner: LH: 6822012160 01 1983/05-1987/04 AE8# USD 28.10/33.25 RH: 6817012230 01 1983/05-1987/04 AE8# USD 28.10/33.25 Hinges: Upper: LH: 6872014030 01 1983/05-1987/04 AE8# PLANT.M21,M22 USD 32.00 LH: 6872032010 01 1983/05-1987/04 AE8# PLANT.A51-A54 USD 26.23/32.23 RH: 6871014030 01 1983/05-1987/04 AE8# PLANT.M21,M22 USD 33.36 RH: 6871032010 01 1983/05-1987/04 AE8# PLANT.A51-A54 USD 26.23/34.24 Lower: LH: 6874024010 01 1983/05-1987/04 AE8# PLANT.M21,M22 USD 32.00 LH: 6874032010 01 1983/05-1987/04 AE8# PLANT.A51-A54 USD 26.04/33.89 RH: 6873024010 01 1983/05-1987/04 AE8# PLANT.M21,M22 USD 32.00 RH: 6873032010 01 1983/05-1987/04 AE8# PLANT.A51-A54 USD 22.79/31.89 RH REPLACEMENT PART: 6873030090 USD 27.48/32.11 Front window corner trim LH: 75717 COVER, FRONT DOOR BELT MOULDING END, FRONT LH 7571719015 01 1983/05-1987/04 AE8#..APX,GL,GT,GTV,SR USD 19.06 FABRICA MI DIEM, PVNC! |
11-05-2014, 04:44 PM
Post: #438
Nice link!
11-05-2014, 04:48 PM
Post: #439
(11-05-2014 04:44 PM)banpei Wrote: Nice link!Indeed pity Toyodiy doesn't show pictures anymore, used it so many times. AE86 ex-daily |
11-05-2014, 04:50 PM
Post: #440
Indeed. And I got rid of my laptop with XP on it and for some reason can't get the EPC to work on 7.
![]() Besides that: online is far more convenient. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
My little (not really...) project - Soon to be all done?!? | Jan Pedersen | 516 | 603,020 |
Another SR20DET conversion allmost done :) | peter møller | 7 | 16,131 |
Yay! Its now done and on the road! | Black Betty | 24 | 23,470 |
Bodywork in 3 steps | max_ae86 | 67 | 62,340 |
