JDM MAP ECU Differences
02-14-2007, 10:22 PM
I have two JDM Map ECU
89661-12050 -> 05.1983 - 09.1983 (Zenki) and 89661-12150 -> 05.1985 - 04.1987 (Kouki) Are these two interchangable? |
02-14-2007, 10:23 PM
Looks like its been covered here: http://www.aeu86.org/viewtopic.php?t=2779&highlight=ecu
Can someone tell me if there are differences in performance. |
02-14-2007, 10:53 PM
No difference worth bothering about... small differences in rev limit have been mentioned before.
02-15-2007, 12:52 AM
Can I interchange these two ECUs? I don't seen any differences in the distributor, coil/igniter, TPS Sensor between the zenki and kouki models.
02-15-2007, 06:57 PM
You found the thread about this subject, if you have read it carefully you would have noticed that no, you can not interchange the ecu's between zenki and kouki models.. at least not for MAP sensored engines. I have tried that once already. You can always try, nothing got broken when I did, just dont be surprised if something goes wrong.
AFM to Map Conversion | ps13michi | 3 | 3,601 |
Clutch differences LUK vs Exedy | r.ave | 2 | 5,310 |
05-27-2021 09:30 AM Last Post: r.ave |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,830 |
4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 90,308 |
05-05-2019 04:03 AM Last Post: Rocker100 |
extracted freedom ecu 16v ignition map | ditn | 7 | 9,293 |
