JDM MAP ECU Differences
02-14-2007, 10:22 PM
I have two JDM Map ECU
89661-12050 -> 05.1983 - 09.1983 (Zenki)
and
89661-12150 -> 05.1985 - 04.1987 (Kouki)
Are these two interchangable?
02-14-2007, 10:23 PM
Looks like its been covered here: http://www.aeu86.org/viewtopic.php?t=2779&highlight=ecu
Can someone tell me if there are differences in performance.
02-14-2007, 10:53 PM
No difference worth bothering about... small differences in rev limit have been mentioned before.
02-15-2007, 12:52 AM
Can I interchange these two ECUs? I don't seen any differences in the distributor, coil/igniter, TPS Sensor between the zenki and kouki models.
02-15-2007, 06:57 PM
You found the thread about this subject, if you have read it carefully you would have noticed that no, you can not interchange the ecu's between zenki and kouki models.. at least not for MAP sensored engines. I have tried that once already. You can always try, nothing got broken when I did, just dont be surprised if something goes wrong.
  AFM to Map Conversion ps13michi 3 3,210 01-06-2022 10:34 AM
Last Post: ps13michi
  Clutch differences LUK vs Exedy r.ave 2 5,089 05-27-2021 09:30 AM
Last Post: r.ave
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,095 02-10-2020 06:39 PM
Last Post: Power_uP
  4AGE block differences explained (incl. some eyecandy) Bean 46 87,603 05-05-2019 04:03 AM
Last Post: Rocker100
  extracted freedom ecu 16v ignition map ditn 7 8,872 08-22-2016 10:01 AM
Last Post: ditn
