KAAZ 2 way LSD
12-23-2007, 12:26 AM
KAAZ 2 way LSD
Hi mates,
As you know i fitted a KAAZ 2 way LSD in my AE86.
I had already performed the break-in procedure as explained on KAAZ site and changed the diff oil (i'm using now the KAAZ oil).
However, there still was many noises (chattering and clunking) coming from the rear end.
Today i drove the car for 100 Km on a twisted road and i think it didn't change anything.
Do you know after how many km the LSD will become quiter?
Because it's very annoying to drive the car in this condition, especially on the city.
Everybody on the sidewalk stands looking to the car waiting for something to break.
I'm already considering buying another LSD (1 way or something less hardcore)...
Thanks for your help...
Keeping the AE86 alive!
12-23-2007, 04:37 PM
KAAZ 2 way LSD
our Kaaz got quieter after we changed to different oil though it'll always be rather on the noisy side... (xperience form 200sx that is)
12-23-2007, 05:35 PM
KAAZ 2 way LSD
I have instaled a TRD 2.0 ways LSD and have been making a lot of noise for something like 8000km...
Regards
Cheers
Miguel
12-23-2007, 09:07 PM
KAAZ 2 way LSD
I had lots of noise after my first oil change. I guess it didn't really break in after those 8-figures and first oil change.
I changed the oil then for the second time and it became very quite, like the stock lsd.
I only hear my ring and pinion now, but that doesn't have much to do with the lsd.
I use Valvoline 80W90 LS.
12-24-2007, 03:12 AM
KAAZ 2 way LSD
Hello
I would recommend using a 75W140 oil for a 75% LSD. I use Castrol SAF-XJ.
BG raki
http://www.sg-rallyesport.de
12-24-2007, 07:19 PM
KAAZ 2 way LSD
Thank you very much for your opinions...
I will wait some more kms
12-25-2007, 12:21 PM
KAAZ 2 way LSD
It will get quieter Thumbs up!
12-26-2007, 09:35 PM
KAAZ 2 way LSD
I would change the oil one more time.
The brake in procedure is not really fully engaging the lsd plates.
My lsd became loud after the first oil change when I did some donuts/drifting.
At first I thought that is was normal, you always hear people say lsd's are noisy. But I decided to change the oil one more time to be sure.
So did that and my diff has been as quite as the stock unit since then!
I just think that the oil was "worn out" very fast after the first real work of the lsd plates.
So I would try that instead of waiting for it to become quite by itself. Wink
12-31-2007, 03:49 PM
KAAZ 2 way LSD
Hi,
I've changed the oil again and now it's much more quieter...
I used the Silkolene 75W90 that i use in my Evo VI differentials and gearbox.
Thanks for the help.
12-31-2007, 04:14 PM
KAAZ 2 way LSD
rasteirinho ... you have to use LSD oil ... gearbox oil will premature wear you LSD
from Silkolene you have the " Silkolene BOA 90LS "
This Silkolene BOA 90LS oil is specifically designed for use in high performance (plated) limited slip differentials (LSDs)
This includes the LSDs fitted to cars like the BMW and Toyota Corolla as well as aftermarket LSDs like Kaaz, Cusco, TRD, OS Giken
from motul you have the MOTUL 90 PA LIMITED SLIP DIFFERENTIAL FLUID
Specially designed for limited slip differential and hypoid gear rear axles, this high performance mineral gear oil is perfectly suited for use in racing cars, 4 x 4's and passenger cars. If you have aftermarket clutch type LSD's (Nismo, KAAZ, Cusco, Mazda Comp. etc.) this oil is meant for your clutch type LSD. API GL5, MIL-L-2105-D, ZF TE ML.
there are some oils specially designed for limited slip differentials , they are hard to find in Portugal though
normal gear box oil will trash your LSD plates in no time ....
  Kaaz 1.5 way Diff - Driveshaft Compatability chrisae86 1 2,961 05-10-2021 01:02 PM
Last Post: Project D
  Help needed: is it 1 way or 1.5way LSD Dino86 2 4,323 05-17-2019 09:08 AM
  Tomei 16V poncams + Tomei technical trax 1.5 way LSD Lt86 22 23,078 09-16-2016 09:56 PM
Last Post: Alex170984
  Kaaz width doubt, OEM is out of car T_AE86 3 5,951 04-13-2013 12:05 AM
Last Post: T_AE86
  corolla idles way to high HELP PLEASE 86_ae86_coupe 9 10,806 12-01-2011 10:05 AM
Last Post: Uzelac
