Koni front shock...
11-04-2007, 04:32 PM
Koni front shock...
Sorry but I've been looking for answers but haven't found ;(
I tried to fit koni dampers on AE86 strut but they don't seem to fit, I explain I plugged them but I can't screw the upper bolt on strut....
I saw that it was possible to cut the down part of the damper but they came from my previous 86 and It wasn't cut???!!!
Someone could helo???
Thanks
1982 Toyota Corolla KE70
1992 Subaru Legacy BF5T
11-04-2007, 06:12 PM
Koni front shock...
Yes, that is meant to be cut to fit the AE86 strut!
Best regards
11-11-2007, 10:58 PM
Koni front shock...
PN# of the shocks (just to check) ?
So the shock inserts are too long ? For your 100% stock AE86 shock housings ?
11-11-2007, 11:42 PM
Koni front shock...
Yes it's that...
But I cut Sad
11-11-2007, 11:47 PM
Koni front shock...
Didn't understand.
You cut your housings and now you can't use stock size KONIs ?
Just make new looong caps (screws) for the housings Smile
11-14-2007, 10:07 PM
Koni front shock...
The koni's have little metal tails that are meant to be cut to make the shocks fit the strut perfectly. You can cut them in 2 or 3 steps, but so far every koni shock I've encountered needed the maximum amount cut off from the bottom. Hope that helps.
11-15-2007, 06:50 PM
Koni front shock...
if you cut maximum your nut doesnt grip the shock and it is loose in the strut...
You can do this:
cut to the last part... as low as you can get it...
[Image: AEU86 AE86 - Koni front shock...]
but then the nut doesn't fit
In my case even the KONI nuts didn't fit.
So what do you do?
then you machine (grind) the inner side of the stock nut... like so:
SNO-MO-BIRU project started- CHIRO
11-15-2007, 09:48 PM
Koni front shock...
I cut at the maximum I could...
I ain't no problems with the nuts but there's too much rebound so I think I will do a short stroke modificaction...
11-16-2007, 01:19 AM
Koni front shock...
NOOOOOOOOOOOOOOOOOOOO
I had this problem with Bilstein too... take the gland nut(top nut you show being machined) put the nut on the shaft. slide it down to the base. with shock upside down and using a piece of wood as an anvil, tap the bottom of the shock till the nut seats around the damper. THEN install shock and nut into strut tube and rotate gland nut till it catches
Dan -
  KONI Sports shocks for the AE86... jondee86 11 20,586 09-08-2017 03:38 AM
Last Post: jondee86
  Problems installing yellow koni's in my TE71 liftback teun 12 15,630 11-09-2013 03:01 PM
Last Post: teun
  Question about KONI shocks for an AE92 Apsogos 1 4,077 09-13-2013 07:40 AM
Last Post: Apsogos
  Coilover shock replacement phill 92 9 11,500 08-28-2012 08:46 PM
Last Post: phill 92
  Maybe problem with TRD shock absorber and springs Mattolo 22 20,531 10-15-2011 07:40 PM
Last Post: zenki
