Kristian from Sweden
09-13-2004, 10:07 PM
Hmmm
Now I need to go steal the shocks of my mate that just bought a 325 ![]() ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-14-2004, 12:25 AM
BTW, could you tell me some more about the lexan windows? I'm still very interested in the details. You have my email. Thanks
09-14-2004, 01:40 AM
Ivan........
I could make them for you & send then to you if you like. it would be 2mm or 3mm of your choice ! difference in price is..... 1 square meter 2mm Lexan = 20 Euro 1 square meter 3mm Lexan = 30 Euro I doubt that shipping would be very expensive. the only problem is that you cannot roll upp & down the windows with Lexan windows. I have mine secured with an m6 bolt/nut but do you also want the rear window ? K I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
09-14-2004, 01:42 AM
Ivan141 Wrote:I thought you had coilovers on order a while ago..my bad. I just ordered my tokico blues today, should be receiving them in a few weeks. You sure you dont mean HTS or illumina? Tokico HP (blues) would blow prematurely Well... my car is lowered 5" = 13cm. The boxes that the shocks came in said Tokico Blue (even on the Tokico sticker) & i have had no problems with the shocks at all yet. I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
09-14-2004, 01:44 AM
mux213 Wrote:Hmmm Hey.. you have missunderstood me a little. ![]() only the rear SPRINGS of an 325 E30 will fit the AE86... not the shocks. Also.. A small tip --- is that the rear shocks of an NIssan Cherry Turbo will fit to 99%.. all you have to do is change the rubber bushing on the lower mount K I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
09-14-2004, 08:16 AM
Hey Kristian, I understood you, just made a typo there, my mind works strange like that sometimes
![]() Those lexan windows are interesting, I still need some for my RX7... ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-14-2004, 08:49 AM
Hi Kristian,
Very nice car you have there, although I liked it best when it was just a clean white car without the stickers (but then i'd like sponsors paying part of the bill as well ![]() Could you do me a favour regarding the shocks? When you have some spare time, could you just peak under the car and measure the distance between the end of the shockbodies and the bumpstops? With the usual tokico blues this distance should be zero, thus eliminating the shocks and springs ability to do any work. Perhaps you have some special shortened edition? If people would start to buy the ordinary blues and dropping the car 13cm they would be in for a suprise... A wheel to steer the front of the car A pedal to steer the rear |
09-14-2004, 10:06 AM
Hi Kristian,
Great car! I bought mine also with drifting in mind ![]() Have fun drifting (still downloading) Michel Daily driver: Seat Leon Cupra V6 Summercar: E30 M3 Cecotto Projectcar: AE86 |
09-15-2004, 12:09 PM
Välkommen, välkommen Kristian!
09-15-2004, 03:07 PM
Wow, that's pretty cheap for lexan! I'm assuming you wont be able to roll up the windows anymore because they lack anti scratch coating, or is it because you wanted to save weight by removing the window mechanism?
I'm going to give my friend over at GE a call, see what basic 3mm lexan would cost per square meter. At 20 euro's per square meter i can afford to replace them once in a while, as long as I can still open my windows. I'm only doing the side windows by the way, unless lexan doesnt fog like ordinary glass does, that ,might be a reason to think about replacing the rear glass. (It's not as big of a window on coupe's as it is with hatchbacks so weight is less of a problem.) Did you need to bend the lexan to make it fit or is it a flat piece? If it's flat I can make it myself. FABRICA MI DIEM, PVNC! |
Hello from Sweden | Skyracer | 5 | 6,215 |
01-11-2012 07:25 PM Last Post: Skyracer |
New guy in Sweden :) | krullibull | 21 | 20,307 |
05-30-2011 03:28 PM Last Post: kennedy8383 |
New member from Sweden! | Bentley | 12 | 12,791 |
04-30-2011 12:25 PM Last Post: Ivan141 |
New Member. Sweden Stockholm | Allexz | 5 | 6,053 |
10-18-2007 05:25 PM Last Post: S.K. |
Hello from Sweden! | Hedlund | 4 | 5,074 |
03-18-2007 09:26 PM Last Post: S.K. |
