***Ksport*** What about theese coilovers? Cheap?
01-24-2007, 10:30 AM
Post: #61
Ok, tnx. ABout NRCA's - the price is 120$ on t3. normal RCA's 70$, and im sure you know, camber plates are 170$. So those NRCAS are 120$ against 240$ for CP's and normal RCA's. Thats why i thougt about them. on 4 cm lowering they're suppossed to give some 2.5-2.7 degrees of negative camber. Which is i think just about right. What would you suggest?
01-24-2007, 10:34 AM
Post: #62
These calculations are correct. But that way your camber setting will be fixed vs adjustable one (via CPs).
01-24-2007, 04:09 PM
Post: #63
Sorry Jamie, but the cad model was like 2 years and 3 computer crashes ago.. It was just a simple parametric model I made to help understand the roll geometry of McPherson setups, nothing too accurate just rough measures.
01-24-2007, 04:10 PM
Post: #64
You made it once - you can make it again with less problems Tongue
01-20-2010, 08:11 PM
Post: #65
Anyone know where go get cheap ae92 Koni shocks?
here i think pair was near 400eur if the adjust is top of shock,
  Carina drivers! - Coilovers for a TA60/62 nyberrg 2 6,255 06-05-2017 10:03 AM
Last Post: nyberrg
  Fitting driftworks CS2 coilovers bozu 2 4,662 05-30-2017 10:50 AM
Last Post: bozu
  D2 Coilovers any good? heshan 18 26,143 04-04-2017 02:40 AM
Last Post: hachirokkos
  Has anyone tried BC Racing coilovers? AlexKTM 9 11,984 09-05-2016 12:28 PM
  Anyone running DIY Coilovers? Rasteirinho 8 13,694 11-19-2013 10:30 PM
Last Post: totta Crolla
