LSD whinning
11-30-2008, 04:34 PM
LSD whinning
Mine was ok until the trackday... Now it whines a bit from 2500 rpm to 3000 rpm (in 5th gear) and then the noise becomes almost unnoticeable.
Keeping the AE86 alive!
11-30-2008, 09:25 PM
LSD whinning
Can you, please, specify which P&R you have, eventyally what LSD?
Thanks
12-01-2008, 11:17 AM
LSD whinning
Kind of an interesting topic Smile Most gear noise is due to the teeth
"slapping" together as they come into mesh. So this noise will follow
the speed of the vehicle... become higher in pitch the faster you go.
Gear mesh noise is greatly influenced by the setup of the gears.
Traditionally, these are designed to have an eliptical contact patch
centred halfway up the tooth, and biased towards the toe of the tooth
during setup. Under load, the contact patch will enlarge and move
towards the centre of the tooth width.
A contact patch that is not centred will result in high tooth pressures,
edge contact, vibration and noise !! It is also very important to use
a high quality oil specifically formulated for differential use.
And it is also worth remembering that the harder your suspension
bushings are, the more noise they will transmit into the car interior.
The same metal box you painstakingly stripped of all sound insulating
materials to save weight :-D
Cheers... jondee86
  Upgrading no-LSD diff to LSD one Snejk 22 19,680 04-01-2008 04:46 PM
Last Post: Snejk
  Not understanding LSD - how LSD works surfingdrums 11 16,685 09-13-2006 11:58 AM
Last Post: Mux213
User(s) browsing this thread:
