Lambda sensor
10-27-2009, 12:08 PM
Lambda sensor
I want to fit an aftermarket wideband system to my '86, it has a tubular 4 into1 manifold and will likely be running carbs. I guess the best place to fit the sensor is in the end of the manifold tube after the collector and before it goes into the exhaust. Can anyone confirm this please.
10-27-2009, 02:53 PM
Lambda sensor
Confirmed
10-27-2009, 05:28 PM
Lambda sensor
![]() ![]() An analogue brain in a digital World |
10-27-2009, 09:33 PM
Lambda sensor
Check the installation recommendations available from a wideband
supplier such as Innovate. The bung needs to be in the top half of the tube/pipe, and preferably on top. This is to reduce the possibility of condensation hitting the hot sensor at startup. Cheers... jondee86 |
10-28-2009, 05:02 AM
Lambda sensor | |||
10-28-2009, 09:54 PM
Lambda sensor
so glad I checked first, thanks to all above !
Lambda sensor wiring | sam3007 | 10 | 5,472 |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 21,574 |
09-06-2014 05:47 PM Last Post: izanagi |
Hall sensor | totta Crolla | 7 | 8,895 |
02-28-2014 10:07 AM Last Post: Ivan141 |
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 11,880 |
10-25-2013 05:13 PM Last Post: Apsogos |
1/8 BSPT adapter for oil pressure sensor | Dino86 | 4 | 7,615 |
06-15-2013 12:34 PM Last Post: S.K. |
