Lambda sensor
10-27-2009, 12:08 PM
Lambda sensor
I want to fit an aftermarket wideband system to my '86, it has a tubular 4 into1 manifold and will likely be running carbs. I guess the best place to fit the sensor is in the end of the manifold tube after the collector and before it goes into the exhaust. Can anyone confirm this please.
10-27-2009, 02:53 PM
Lambda sensor
Confirmed
10-27-2009, 05:28 PM
Lambda sensor
Cool Thumbs up!
10-27-2009, 09:33 PM
Lambda sensor
Check the installation recommendations available from a wideband
supplier such as Innovate. The bung needs to be in the top half of the
tube/pipe, and preferably on top. This is to reduce the possibility of
condensation hitting the hot sensor at startup.
Cheers... jondee86
10-28-2009, 05:02 AM
Lambda sensor
Placement info from Techedge.
http://wbo2.com/lsu/position.htm
10-28-2009, 09:54 PM
Lambda sensor
so glad I checked first, thanks to all above !
Thumbs up!
  Lambda sensor wiring sam3007 10 4,462 05-23-2022 10:00 PM
Last Post: The Doctor
  AE86 Engine Coolant Temp Sensor izanagi 8 20,387 09-06-2014 05:47 PM
Last Post: izanagi
  Hall sensor totta Crolla 7 8,333 02-28-2014 10:07 AM
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 11,033 10-25-2013 05:13 PM
Last Post: Apsogos
  1/8 BSPT adapter for oil pressure sensor Dino86 4 7,068 06-15-2013 12:34 PM
Last Post: S.K.
