Leaking sunroof...
01-30-2005, 10:58 PM
Leaking sunroof...
Does anybody know where i could find the rubber seal for my pop-up sunroof? It started to leak when it's raining. The type is
FARMONT TECHNIK Type : JUWEL KBA 9306 If i can help you a Farmont dealer in Athens said that the code for that is 1320 but he doesn't have it and he won't have it in the future. ![]() Anybody can help? ![]() Thanks in advance ![]() AE86 FANATIC!!! |
01-31-2005, 10:47 AM
Leaking sunroof...
Join the club man...I have a Farmont roof as well, it leaks like hell and there is little I can do about it.
01-31-2005, 12:00 PM
Leaking sunroof...
Ivan do you know if it's possible to swap my sunroof with the electric one from a donor car GTS TRUENO?
It seems to have the same dimensions with mine (measuring then on the cars). Have you ever heard of such a project? AE86 FANATIC!!! |
01-31-2005, 01:03 PM
Leaking sunroof...
Nope, but I think it's a bit difficult. You can only install it if the existing hole in your roof is smaller or exactly the same size. I think it folds under the roof so there might be some more room under the roof on models fitted with it.
01-31-2005, 01:27 PM
Leaking sunroof...
Ok Ivan!
Thanks a lot anyway ![]() AE86 FANATIC!!! |
Sunroof clips | FanIsHere | 0 | 4,188 |
08-19-2016 11:33 PM Last Post: FanIsHere |
brake line leaking - how to fix ? | MC_JP | 2 | 4,516 |
04-28-2014 09:47 PM Last Post: MC_JP |
Sunroof Controller Diagram | Serencebey | 2 | 4,954 |
02-24-2010 05:11 PM Last Post: Serencebey |
problem again , about leaking half shaft bearing | filh | 10 | 10,634 |
03-22-2009 01:03 AM Last Post: filh |
Oil leaking from top but its not broken ??? | Allexz | 4 | 4,938 |
05-09-2008 07:48 PM Last Post: nikos_trd |
